Ideapad 130-15IKB, LA-G202P rev.1.0 no picture, +VCCGT
    Hi people,
    Ideapad 130-15IKB
    LA-G202P
    CPU: i5 8250U
    The laptop turns on without picture. All voltages are present except +VCCGT. Probably POST not starting because current stays around 300mA. I've checked resistance and voltages:
    PL602 - 28ohm - 1.0 VALWP - 1.04V present
    PL502 - 231ohm - 1.2VP - 1.2V
    PLA1 - 17ohm - VCCSA - 1.03V
    PLZ1 - 4ohm - VCCCORE - 0.84V
    PLZ2 - 4ohm - VCCCORE - 0.84V
    PLG1 - 7ohm - VCCGT - 0V
    The VCCGT comes from PUG1 (RT9610CGQW). Signals are:
    EN-5V,
    PHASE-0V,
    UGATE-0V,
    BOOT-4,7V,
    PWM-2.5V,
    LGATE-0V,
    VCC_GT-5V
    PWM signal comes from PUZ1 (RT3602AE). All mosfets are good. I have noticed that PWMs on PUZ2 and PUZ3 (responsible for VCCCORE) are 0.22V, and also comes from PUZ1.
    I have already replaced PUZ1, PUG1,reprogrammed BIOS and EC. No change and no ideas, what to do next. Oscillators 32kHz and 25MHz are working. The RSMRST is high so I assumed that EC is good.
    Re: Ideapad 130-15IKB, LA-G202P rev.1.0 no picture, +VCCGT
    Usually no point to troubleshoot +VCC_GT, since the voltage appears only under load, so the mess there was likely for nothing.
    Same for RSMRST# when the board reaches the late sequence.
    I'd stay at BIOS instead, and check whether PLT_RST# and DRAMRST# are present.
    You might want to restore all the firmware you have played with so far, to have a good start point.
    FairRepair on YouTube
      Thanks Sephir0th for the answer.
      About bios: I used latest available from Lenovo website. After replacing ICs I have returned to original bios file.
      DRAMRST# is low all the time, about 76mV. PLTRST# is 3.3V. I hope I've found the right place to measure it (picture).
        Yeah, that's fine but also check at Y-Pin for sanity. DRAMRST# staying low is actually a bad thing. Please double-check.
        RAM is known good?
          Y-pin is also 3.3v. RAM is onboard. But there is one DIMM slot. I used good RAM but no effect.
          I've checked DRAMRST# with oscilloscope. It stays low all the time.
            If BIOS was ruled out for sure be sure, i'm afraid to share we're likely dealing with a dead CPU/PCH here.
              OK, so I have another donor for my collection. Thanks for help.
              Does always low DRAMRST# mean faulty CPU/PCH? Could you explain it more?
                it usually means that either your soc/cpu or the firmware is faulty (there are exceptions...). it's one of the last rails that starts in the power sequence (block diagram).
                  I'll bet for a faulty onboard ram here. If you have access to schematic and boardview, disbale the onboard ram and put up a known good ram stick. Lenovo and asus are notorious for onbaord ram issues.
                    ah sure, there is soldered ram. this is the best advice! the amps read are a big clue for ram issue.
                      Hi, sorry for the absence. There is only schematic available, so finding those resistors is imposible for me.
                        Yes, no point trying to disable ram under darkness. Its impossible to do without boardview.
                          we can disable ram on board by bios modified.
                            Could you guide me, how to do it?
                              Serach on Google for "spd bios onboard memory removal"
