Toshiba 58UL2B63DB Suspected Bad Panel
    Re: Toshiba 58UL2B63DB Suspected Bad Panel
    This video explains how to find the right signals to block, at the counter 5:18
    https://www.youtube.com/watch?v=SbGAkRgaZhs
      will a new t-con board fix this problem
        The problem of op is panel related, a new tcon can not cure his problem, if you have the same issue, do as he did, watch the videos linked, 3 videos linked, watch them all, couldn't hurt, sometimes you have to play with what line/s are blocked with the tape.
          I used a paper strip just wide enough to cover the first 8 contacts on the right hand side of the cable that had the problem. Tv is still good now.
            I have the same problem.
            Do you cover the first 8 contacts on the right hand side of the left ribbon ?
              You unclip the cables one at at time and then turn on the tv to find out which side has the problem. Then you cover the first 8 contacts on the right hand side of the cable that had the problem.
