Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 12-01-2022, 08:44 AM   #1
ronni
City & State: Bedford
My Country: UK
I'm a: Knowledge Seeker
Default Sony KD-43XE8005 with sound, backlight, no picture
I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
Removing the LVDS cable results in neither a picture or white screen being displayed. When the right hand T-con cable is removed nothing is shown on the screen, only a backlit screen.
So far I've changed the T-con board for one of the same part number with no improvement. Reading through other posts it points to a faulty panel, but the 'flickering picture when rubbing the right hand t-con ribbon cable' is throwing me off, so I've ordered a replacement ribbon cable.
Any ideas of what to test/replace next? Thanks
ronni is offline   Reply With Quote
Old 12-04-2022, 08:54 AM   #2
nomoresonys
City & State: midwest
My Country: U.S.
Default Re: Sony KD-43XE8005 with sound, backlight, no picture
maybe try the tape cut-off method.
nomoresonys is offline   Reply With Quote
Old 12-04-2022, 10:19 AM   #3
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
The skinny little board with the tab bonds going to the LCD, look there for shorted SMD cap(s). There should be also test points to measure voltages.
CapLeaker is offline   Reply With Quote
Old 12-15-2022, 10:52 AM   #4
ronni
My Country: UK
Thank you both for the replies. I'll try taking a closer look at the caps, test points and the tape cut-off method
Old 01-04-2023, 11:50 AM   #5
ronni
My Country: UK
I looked into the tape cut-off method, the CLK lines are only on the right (working) side. So I taped the clock lines 1-8 but there was no change on the left hand side of the screen.
I'll take a look at testing all the caps on the panel interface boards
Old 01-06-2023, 06:39 PM   #6
Jackplug 123
Retired tech
Jackplug 123's Avatar
City & State: Stoke-on-Trent
My Country: United Kingdom
Line Voltage: 240Vac 50Hz
Take a look at my posting a 49 inch Sony, solution posted last Sunday, looks like a similar TCON board too.cheers Jackplug 123
Jackplug 123 is offline   Reply With Quote
Old 01-10-2023, 11:45 AM   #7
ronni
My Country: UK
Quote:
Thanks for the message. I saw your thread and was following your progress. It's great that you got it working but doing the same on mine unfortunately doesn't have the same outcome. I'll try identifying any faulty caps and go from there
Old 01-10-2023, 06:57 PM   #8
Jackplug 123
Retired tech
Shorted decoupling caps on the thin driver board could be the problem.
I was about to check mine,but to expose the board involved a bunch of screws removing on the bottom lcd screen frame section.Decided to try the tape method first, my next task is to isolate the bad clock line or lines out of 8 lines.
However the initial result was surprising good picture.
Have a look at Michael Dranfields videos on YouTube,one deals with a set with shorted caps.He uses a milli ohm meter to narrow the field down.Good Luck.
Old 01-10-2023, 09:57 PM   #9
nomoresonys
My Country: U.S.
good call, Michael has good videos.
Old 01-18-2023, 09:05 AM   #10
ronni
My Country: UK
Thanks Jackplug. Took a look at his vids. I've found a couple of shorted caps on both sides of the screen. Looks like I'll be building a milli-ohm meter next!
Michael Dranfield's video for future reference:
https://youtu.be/77tymvTJDxo?t=887
Old 01-18-2023, 09:21 AM   #11
nomoresonys
My Country: U.S.
Actually post #3 said to test those caps.
Old 01-18-2023, 09:38 AM   #12
ronni
My Country: UK
Quote:
CapLeaker did indeed say to test those caps. Unfortunately I was in the same position as Jackplug...taking the easier route of trying with the tape method first. When this didn't work I removed the rest of the frame and located the caps. Michael Dranfield's video will help in locating the shorted cap through the use of a milli-ohm meter
Old 02-04-2023, 07:18 PM   #13
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
there's no need of milli ohm meter, cap finding can be made by an average multimeter in ohm..
Davi.p is offline   Reply With Quote
Old 02-05-2023, 04:59 AM   #14
nomoresonys
My Country: U.S.
^if you would have bothered to watch the video, you would discover that yes many times a milli-ohm meter is needed to find the bad cap efficiently , why do you think they were invented.
Old 03-23-2023, 10:19 AM   #15
ronni
My Country: UK
Just an update...I built a milli-ohm meter to identify the bad cap, desoldered it and now the previously white side of the screen is working but with a missing large vertical strip. The left side of the screen is now white so I'll go re-check those driver board caps
Old 03-23-2023, 11:00 AM   #16
Diah
City & State: SA
My Country: Germany
I'm a: Professional Tech
what is that on the ground ??? the TV COFs!!!!
Diah is offline   Reply With Quote
Old 03-23-2023, 11:19 AM   #17
ronni
My Country: UK
Quote:
The COFs are covered by the metal bracket are not touching the ground
Old 03-23-2023, 12:23 PM   #18
nomoresonys
My Country: U.S.
Did you replace the shorted caps?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2023
Powered by vBulletin ®
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
