Sharp LC-65N7004U / 65A6100M not powering on
    Hello Badcappers,
    I have this tv that does not turn on. There are 2 model numbers on it : LC-65N7004U and 65A6100M.
    When powering on the tv, the Sharp logo briefly appears with a dim S, and the tv turns off. While the Sharp logo is on the screen, the power light will blink 6 times (the last blink being very very quick).
    I suspect a bad LED driver, or bad LED(s). Do you have any suggestion on how to troubleshoot this ? I have ordered a LED tester and should be getting it next week
    Here is a link to a video showing what happens:
    https://youtube.com/shorts/hkBjgBdAios
    Thanks for your help !
    Re: Sharp LC-65N7004U / 65A6100M not powering on
    maybe try some resets first, be CAREFUL if you go into service menu, setting something wrong in there could brick/mess up your tv.
      I haven't found any service manual for this model, so I don't know how to load the service menu. The TV shuts off after like 5 seconds
        see if that helps: https://www.youtube.com/watch?v=ZAvXsglOIL4
          I believe on some sharps it's channel down and input that you need to hold while plugging in to get to service menu.
            Unfortunately there is no button on the TV itself, other than the power button. I've tried holding it a few seconds, or even holding while unplugged then plugging in, nothing seems to work. It feels like bad leds, but cant be overridden it seems.
              Bad LEDs are typical on these
                I wolud do one more easy test before tearing it down to backlights, what do you have with just one ribbon cable attached from tcon to panel, do both sides, see if you get any display, careful not to let the pins of the disconnected ribbon cable touch the metal chassis or anything, make all cable connections and disconnections with tv unplugged from power.
                  hmmm I didn't try with half of the panel connected. I could try that later
                    Well, just an update : there was one bad LED but I ended up replacing the whole set of loght strips and everything is now back to normal operation !
                    Thanks for your help and suggestions
                      Nice work saving that 65 incher.
                        Hi Vizion ,
                        I had the same model 65a6100m, the same issue sharp, red-light blink fast for 6 times, last 6th blink is fast , sharp logo appear for a second then shutdown.
                        How to fix this. Do I had to open its back cover?
                        Or what light stipe to order?
                          Originally posted by Takayalee View Post
                          Hi Vizion ,
                          Hi Takaya,
                          You need to take the tv apart completely
                          This includes (but might not be limited to, as i dont remember all the steps I did) : remove back cover, remove ribbons from tcon to panel, unclip the 4 boards at the bottom on the frame, remove the outer frame, remove the locking plastic strips around lcd, remove lcd, remove plastic diffusers, remove white background, remove strips and glue new ones in place reassemble in reverse order
                          I have ordered a set of these from this seller
                          https://www.aliexpress.com/item/1005...3eb51802kUmNfH
                          Quite cheap and worked ! It took about maybe 2-3h total. Ive glued the strips with silicone caulking.
                          Hope that helps !
                            THanks so much, So happy that you reply so fast.
                            1. This video can use as a method to take every apart ??
                            https://www.youtube.com/watch?v=ZGR1tTlbPXw&t=205s
                            2. and when remove the glue strip. it's need hairdryer to heat it up? before remove it?
                            3. general white silicone caulking work? or it's need any specific one?
                            Thanks so much ViziOn
                            Originally posted by vizi0n View Post
                            Hi Takaya,
                            Hope that helps !
                              In the video the strips are screwed in, but on these tvs the strips are glued with some black stuff and some tape as well. You will understand when you get there
                              To remove the strip i’ve juste lifted one end of the strip and pulled. Since i was not reusing I just pulled hard.
                              Regarding silicone, its because that is what I had on hand. Just make sure that you make it as thin as possible so that the strip lays flat. Also wait for it to cure for a few hours before lifting the tv up, just so that the strips dont move/fall because not glued properly. I’ve used a regular household silicone caulking tube.
                                Understood,
                                Already orderone from Ali, 2weeks waiting.
                                I will update when it arrived here.
                                Thank you
                                  Understood,
                                  Thank you
                                  same issue. ordered the LED strips linked above. did it fix ?
