[help]asus gl703ge dead, no shorts!
    Re: [help]asus gl703ge dead, no shorts!
    PU12 pin 6 2,2kohm
    PU13 pin 10 54ohm
      i don't understand where should be the problem...i have no shorts anymore...
        sorry if i insist..i know i'm an idiot....
        i've tried to use my power bench supply...
        here's the result
        https://files.fm/u/zdpyhhykv
        and this is with thermal camera
        https://files.fm/u/7xjxemry8
          The current draw is very low.
          Confirm that your ACDRV is ~25v to enable the DCin mosfets and that the 20v is not from the internal diode of the 2nd DCin mosfet.
            I have the same board, dead as a door knob, i get 20V on the Board,but no 3.3V or 5V, on the PU9 which is RT6575DGQW i have some voltages comming out of the chip, 2.4V and 4.5V,dunno what pins exactly, it was late and i did a quick measeurement, but not getting the correct outputs probably, no shorts anywehre on the board, so if i change the RT6575DGQW i am good to go?
