Hello can you please tell me the exact steps for updating the tv after logic board replacement.. I try everything I can find online but no luck. I have green and amber light blinking.. thank you in advance
Sony kdl 40ex720 firmware update
Re: Sony kdl 40ex720 firmware update
put your model in there, check downloads, they may have made it no longer available in January 2022: https://www-sony-gr.translate.goog/e...n&_x_tr_pto=sc
do this: rename file on the usb drive folder as: upgrade_loader.pkg, use a usb drive with led light, then put the key on the unplugged tv, now keep pressed power key and plug tv in mains socket, watch if a light will glow, wait for the key light to stop blinking, remove mains plug, wait 10 sec. then plug back, press power on tv, watch if something blinks on tv, when all leds stops blinking turn on tv..
I used an 1gb flash drive and I tried all the information u give me but still the same thing.. when I power on the TV the flash drive flashes for two seconds and then stops and the TV keeps flash amber and green.. do I have to wait longer for the usb drive start flashing again to read the software?
I try every usb flash I can find still nothing..I think the problem its somewhere else.. the story is that I had this tv with double picture and I thought that it was a logic board issue and ruined the cpu on the board.. so then I thought its a tcon problem and I order onother logic board (same model number like the old one but for 46ex720 tv)and when I plug the mains and by pressing the power button on the TV i have immediately green and amber flashing light.. can the tcon with a minor problem cause the TV not to update? Please help me to revive my tv
Try disconnecting the LVDS cable from T_CON and turning on the TV, when the backlight turns on without turning off the TV, insert the cable carefully back quickly and without distortions, an image should appear, reset and update via usb. Do you have firmware PKG4.027EUA?Last edited by lotas; 02-27-2023, 08:41 AM.
