Hello;
I have an ASUS G14 GA401QM that currently has no 5v rail among other things stated below in points #3 and #4. I'd like to see if it's condition can be improved.
1) Originally this laptop had a problem with a shorted main power rail, so measuring at the current sense resistor after the DC IN FETs yielded a very low resistance. Before proceeding further I measured the CPU coils. We get 8.2 Ohms on the farthest right coil (PL8105) and 3.3 Ohms on the four to left left of it (PL8101 through PL8104). When I injected 1v into the current sense resistor, PQH9402 got warm. I removed it and the short disappeared. Replaced it and the short is still gone.
2) Plugging in the power adapter yields no charging light so I disconnect the power. Measuring at the current sense resistor yields a short again. I go back to PQH9402 and measure Pin 1. We're shorted again. I measure PQH9404 and that one is ok. Taking PQH9402 off the board again relieves the short. I have yet to replace it again because clearly something else is wrong.
- PQ9404: Pin #1 in resistance mode measures 3.08 MOhms and in diode mode measures 0.594v drop.
- Where PQH9402 should go: Pin #1 in resistance mode measures 15.55k Ohms and in diode mode measures 0.315v drop.
3) This is where I measured the resistance on the 3.3v and 5v coils. The 3.3v rail at PL8702 measures 3.4k Ohms. Measuring Pin #8 on the BIOS chip in diode mode reads 0.133v drop however reads 595 Ohms in resistance mode, when it should be in the kOhms.
4) The 5v coil at PL8701 measures 12.9 Ohms and the coils for the VRAM right next to it at PL9402 and PL9401 measure 14 Ohms. This is about half of what it should measure.
I don't know where to go next although I have a few pointers to what the issue might be. I suspect it's either a) The EC, b) a VRAM module, c) the GPU itself, or d) A failing PCH.
In any case, it seems like the 5V rail is out with a kill list unless I'm missing something and it's actually another rogue voltage rail.
Schematic and boardview are attached.
