Greetings fellow forumers.
The reason i'm writing this post, is to find some people who have more experience than me on electronics repair. The last month i've been dealing with an Asus laptop (ux510u) that didn't let the charger's voltage pass through the first two MOSFETs. I manage for find some burned/shorted components and replace the parts (most probably the ones that got damaged by the short), but the last one seemed like a stone that im not feeling 100% confident that is creating the issue at all. I found a whole array of caps next to the CPU which seem shorted to ground together with another batch on the back of the board. I tried to remove the front caps and the short is still there. Tried to inject voltage but as you may wonder, the CPU is the only part that gets warm. Now, my thoughts are that if i re-ball the CPU bga i may fix the whole issue, but before even i try to remove the chip, i said, hell, let's get the chance to ask for some help, you never know. I'm based in Greece so if in any case someone from the same country would like to spare some time, i could even make a phone call to give more details, but i'm not greedy, if someone else would like to wrote a line just to share his/her 2 cents i would be grateful.
