The Hall of Shame - Badcaps Photo Montage
This is a sticky topic.
    Re: The Hall of Shame - Badcaps Photo Montage
    Woooaaah!
    http://community.spiceworks.com/topi...en-involved-in
    Muh-soggy-knee
      I wonder how good the overpressure venting was...
        Yeah ... it must have been LOUD!!!
        I wonder why it just failed all of a sudden, after working for many years.
        Muh-soggy-knee
          I've had a PSU primary cap go kaboom before (I put a heap of them into a fire and the vent on one didn't do its job and the can just about went into orbit). That cap looks even bigger and badder, though.
            I found this confusing. These orange Teapo SEK came out of a CWT ISO series PSU. They were on the 3.3V rail. They were getting cooked by a 15Ω resistor wedged between them, they read high capacitance. They have all the same values and codes, and were both manufactured in November, 2006. So....why do they have different rubber seals?! I found this pretty bizarre.
              Variations from batch to batch, or the seal is put on the other way around. Like, transistors from different batches. Even though they have the same P/N, they will have much different HFE value variations than transistors from the same batch.
              Muh-soggy-knee
                I've never seen an orange Teapo SEK until now.
                Those bungs aren't too consistent, though, one just has the concentric bullseye marked into it. But I've seen some Teapos with a bung very similar to Rubycon and NCC bungs. The high capacitance means that the dielectric is significantly thinned.
                As to why they have different bungs...
                To the best of my knowledge, the cheaper manufactures based in Taiwan and China don't actually process most of their materials in-house. They purchase them from other companies and only do the assembling and sleeving of the capacitors, the exception being Yageo's cans; I think with their unique vent that they produce their own cans, but that's it. Most of those companies, unlike the good Japanese brands, are too cheap to do thorough QC testing themselves, or rather the concept itself is foreign or new to them (why you see inconsistent and exaggerated ratings in the datasheets). This is exactly why they are so inconsistent in quality. They are not always buying their materials from the same grade of manufactures so of course their quality is going to vary but will, as a general statement, remain poor because they are only out to turn profits, not produce quality. On the other hand, they wouldn't be in business if all their products were complete crap (that's why Sacon had to change their company name so many times).
                One of the primary issues is the quality of the purity in the aluminum foil. Not only does it fail to meet Dapo's standard but the excessive impurities (such as too much copper) in the aluminum spell certain doom for their capacitors and can ignite chemical reactions (reacting negatively with the cheap, water-based alkalis, acids, or salts used in the electrolyte composition - aluminum has the unfortunate tendency to do that) that cause hydrogen gas to form even on the shelf. Added to that, the electrolyte itself is of poor quality and does not have the proper compounds, cathode depolarizers, or neutralizers to reduce the generation of hydrogen gas and protect the aluminum oxide layer from electrolyte that is aggressive to the oxide film and to the other materials.
                Last but not least, poor bungs guarantee that the capacitors will dry up very fast or that they will certainly leak over time. Most of the time, the good brands avoid this by using better quality seals, very high purity aluminum foil, and electrolyte with the right oxidizers to preclude hydrogen gas and keep the oxide layer (on the anode) stable. But there's more to it than that.
                Achieving good chemical stability relative to electrolyte of internally low electrical resistance with a good dielectric constant and strength is by no means of the imagination an easy feat. This is why the good brands are only a few among the many, many crap brands. And there are thousands of different combinations when it comes to the types of solvents used for the electrolyte, if not more, and some simply have better long term characteristics and stability than others. This is how it's possible for even the "good" brands to have "bad" series. There's simply only so much even the rigorous stress testing can do to foretell long term stability, which is why polymers exist. Their electronic conduction, compared to the ionic conduction of lytics, is much better - the difference is in the order of a hundred fold or more.
                  Don't Yageo caps have the Teapo like vent? The "Y" shape, with three dots/ticks.
                  P.S. You have done 666 posts! xD
                  Muh-soggy-knee
                    I believe Yageo acquired Teapo in 1996, but as far as I can remember, Teapo had a very similar type of vent even prior to the merger so I meant Teapo and/or Yageo when I said that.
                    Not anymore I don't. :P
                      Believe it or not, CWT wanted the 3.3V caps to be orange colored for those ISO psus. I have proof:
                      1st unit:
                      https://www.badcaps.net/forum/attach...3&d=1389575653
                      5V: 2x 2200uF 10V black colored JunFu HK (GP series)
                      3.3V: 2x 2200uF 6.3V orange colored JunFu HK
                      2nd unit:
                      https://www.badcaps.net/forum/attach...1&d=1432852977
                      5V: 2x 2200uF 10V black colored Koshin KRM
                      3.3V: 2x 2200uF 6.3V orange colored Koshin KRM
                        Yeah, I wonder why they do that? I've also of course seen Orange Fuhjjyu TN as well.
                          That is some really really interesting findings!
                          I wonder if they wanted that because the wires on the 3.3V rail are also orange. Perhaps to make it easier for the workers to put those caps in the right spots for the 3.3V rail?
                          My Turbolink PSU has orange Fuhjyyu TNR:
                          https://www.badcaps.net/forum/attach...2&d=1407035562
                          but apparently not all the time:
                          https://www.badcaps.net/forum/showthread.php?t=1221
                          https://www.badcaps.net/forum/showthread.php?t=39222
                            Sanyo WF, datecode 6N, I guess november 2006. HP Compaq DX2300 Microtower with extra fan just above them. PSU is LiteOn PS-5251-08. Caps are OK inside. Seems like single forward or something like that, there is one big primary transistor only.
                              Yup... Suncon WF is like NCC KZJ... doesn't take to heat well at all, and doesn't always fare well sitting in storage either. I see that's a Microstar LGA775 board. What CPU was it powering? If it was a Pentium D, I could attribute the failure to a hot VRM section in this subject of happenstance.
                              EDIT: WGs should be fine. WFs are the trouble makers.
                                Celeron D, should not heat that much. Just loking after some Pentium Dual-Core to place in there…
                                WG are good? Suncon still lists them as active series…
                                  If it was being powered with a quality PSU then I'd say worse than KZJ if they failed on the VRM high. I've seen KZG last 50,000 hours on the VRM high in a mini ATX chassis with poor airflow, with a low ripple In Win unit powering it.
                                    It's one of those strange topologies with single switcher and no Pi coil so who knows what ripple was there.
                                      Is that an Intel DG33xx motherboard or similar by any chance?
                                      Reason I ask is because I have one like it as well. VRM ran so hot that it started killing FETs after a while (that's the one you sent me Pentium4 ). I wouldn't be surprised if those Sanyo WF caps were abused by lots of heat. Don't be mistaken by the fan above them. If it is a mini-tower or SFF, chances are it ran hot enough inside to boil an egg without water. I also have another Intel i965 motherboard. That one was out of a HP DC7700 mini-tower. All of the Rubycon MCZ around the VRM were done to a crisp. VRM had free-standing "hands-in-the-air like you don't care" MOSFETs .
                                      Something tells me Intel sucks at designing VRMs. Or maybe not exactly... but just something to consider before you blame the caps.
                                        ^ That's a MS-7336 with a three-phase VRM and three FETs per phase. I'm not aware of Microstar designing a VRM that qualifies for such depths of suckage and don't think it would have been a problem thermally unless the fans seized. And it was a full size desktop (the HP Compaq DX2300 microtower), to my knowledge.
                                        "Hands-in-the-air like you don't care"...
                                        I noticed many old Dell and Intel (Foxconn or Flextronics) 850 series motherboards use free-standing FETs in the VRM output as well but with lower speed Pentium 4 Willamettes, Pentium 4 Northwoods, and good airflow, they don't actually run that hot in my experience, provided it's a three-phase buck converter with three FETs per phase and that the copper planes are thick.
                                          You are right again. I should have done my research for the DX2000 before commenting.
                                          Looking closer at the picture, the VRM layout on the MSI motherboard looks very similar to my DG33SX, but definitely not the same. In particular, the MOSFETs appear to be soldered on much bigger copper planes. On my DG33SX, they are ridiculously small.
                                          And yes, MSI usually designs their VRMs very well, so then I guess those WFs probably failed all on their own then.
                                          I noticed many old Dell and Intel (Foxconn or Flextronics) 850 series motherboards use free-standing FETs in the VRM output as well but with lower speed Pentium 4 Willamettes, Pentium 4 Northwoods, and good airflow, they don't actually run that hot in my experience, provided it's a three-phase buck converter with three FETs per phase.
                                          Indeed.
                                          However, when it comes to Prescott and Pentium D, you will want things done more seriously. My guess is that's what killed the MCZs on the DC7700 motherboard I got from eBay.
