Thread Tools |
#921 |
City & State: North Springfield, Vermont
Line Voltage: 118-127V 59-63.5 Hz-> actualizo: pérdido de voltaje
![]() Starkly reminds me of an off-brand ATX PSU's marketing watts.
ASRock B550 PG Velocita Ryzen 7 "Vermeer" 5800X 16 GB AData XPG Spectrix D41 Sapphire Nitro+ Radeon RX 6750 XT eVGA Supernova G3 750W Western Digital Black SN850 1TB NVMe SSD "¡Me encanta "Me Encanta o Enlistarlo con Hilary Farr"!" -mí mismo "There's nothing more unattractive than a chick smoking a cigarette" -Topcat "Today's lesson in pissivity comes in the form of a ziplock baggie full of GPU extension brackets & hardware that for the last ~3 years have been on my bench, always in my way, getting moved around constantly....and yesterday I found myself in need of them....and the bastards are now nowhere to be found! Motherfracker!!" -Topcat "did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 |
#922 |
City & State: lima
My Country: lima
![]() hola
#923 |
City & State: lima
My Country: lima
![]() hola es una pru
#924 |
recapping PCB.
City & State: Gerona
My Country: España
Line Voltage: 230VAC 49Hz, 2 Ph
I'm a: Hobbyist Tech
![]() typical fault in ECS MCP61SM-AM (used in HP and Acer)
The OST and TK failed when the computer had more or less 60,000h. I just failed with 70,000h (the HDD is original, and marks 70,000h of use, because its owner never turned it off). Interestingly, all g-luxon are fine: O But I'll be honest, I'm impressed that this board has endured so many hours, and the chipset being an nforce with IGPU has never failed the FCBGA.
Gaming pc: ![]() Workshop PC: Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a. Server: ![]() |
#925 |
A Fake Rubycon
City & State: The Peoples Republic of California
Line Voltage: 122.5VAC 59.9Hz
![]() Generic "CIA LOW ESR" 10uf 400v. Died in under 4 hours in a "2 amp" power supply.
#926 | |||
master hoarder
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
![]() Quote:
![]() ![]() So solution for faulty/dieing GeForce 6100/6150 chipsets: punch them! ![]() ![]() . . . Or just put a 40 mm fan on it, to prevent all of that, if possible. ![]() Quote:
![]() ![]() Last edited by momaka; 04-25-2019 at 09:56 PM.. |
#927 |
A Fake Rubycon
#928 | |
City & State: Jefferson
My Country: LAMBDA SOND
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
![]() Quote:
My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro |
#929 | |
City & State: CA.
My Country: USA.
Line Voltage: 120-125VAC 60Hz.
![]() Quote:
Also, lately I’ve found the early batches of WG and even WX to age poorly, and fail with high leakage current, just like HM, HN, and HZ. In my experience, as far as early ultra low ESR caps go, only MBZ and FJ/FL seem to be safe (even though they’re not impervious to failure, but what cap is?). As far as early “mid grade low ESR” caps go, I’ve had excellent experiences with Rubycon ZL, NCC KZE, and Panasonic FM (which is corroborated by them doing well in Pete’s torture tests from 10+ years ago). Nichicon HD less so but I find they are generally much better than the problematic UESR series mentioned above. That said... I will still take all the above series over Sacon FZ. ![]() |
#930 |
A Fake Rubycon
![]() I currently have a PC set aside with a motherboard full of leaking capacitors, most of the caps are Sanyo WF and OST RLX and just about all of the sanyo WF caps are bulging/leaking while all of the OST caps look fine.
#931 | |
recapping PCB.
My Country: España
![]() Quote:
Thanks for the warning, I'll keep it in mind. If I tell the truth, I do not know what environment it was in, but it was in an Acer case, it was probably working at a low temperature. I do the same to the problematic chips, you put them on a fan and surprisingly the useful life is very long. had a gt8300 with passive heatsink of the defective series, I put a fan and never failed. Surely the company used industrial espionage to obtain the formula for the capacitor. ![]() ![]() Last edited by kevin!; 04-26-2019 at 06:57 AM.. |
#932 |
SNES-powered
City & State: Bacau
My Country: Romania
Line Voltage: 230VAC 50Hz
![]() Sounds like what I had to do on a Fujitsu-Siemens Amillo D7820 - SIS961 southbridge was half dead - literally took a hammer to it, and somehow the whole laptop came back to life, and worked for a long time before finally the LCD inverter board died with glorious sparks. Initially ran 98SE then XP SP3 towards its end of life.
Main rig: Gigabyte B75M-D3H Core i5-3470 3.60GHz Gigabyte Geforce GTX650 1GB GDDR5 16GB DDR3-1600 Samsung SH-224AB DVD-RW FSP Bluestorm II 500W (recapped) 120GB ADATA + 2x Seagate Barracuda ES.2 ST31000340NS 1TB Delux MG760 case |
#933 |
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
![]() It's weird to think that my time as the Torquemada of Capacitors was that many years and two employers ago. It was fun, but the commute was ~75 miles a day,
PeteS in CA Power Supplies should be boring: No loud noises, no bright flashes, and no bad smells. **************************** To kill personal responsibility, initiative or success, punish it by taxing it. To encourage irresponsibility, improvidence, dependence and failure, reward it by subsidizing it. **************************** Anti-Covid-Vaxxer pig crap claim/prediction, Doctor: Heart Failure from mRNA Jabs "Will Kill Most People" | Principia Scientific Intl. ; Dr. Geert Vanden Bossche Warns COVID-19 Jab Injuries and Deaths Will Soon "Collapse Our Health System" (VIDEO) ; Fully Vaxxed May 2021; Since that time I've done 10 5Ks, 1 8K, 8 10Ks, and 4 half marathons |
#934 | ||||||
master hoarder
My Country: U.S.A.
![]() Quote:
MCZ/MFZ is fine, as long as they aren't or weren't overheated previously. Quote:
![]() Might explain why ASUS CUR-DLS has had issues. A year ago, it got corrupt CMOS settings and couldn't detect the SCSI controller until CMOS was reset. Fixed that and it worked for a while. Now it no longer POSTs properly (or rather, hangs after POST.) Maybe it's time to go back where it came from? ![]() ![]() Quote:
Also, one could argue that Panasonic FR and FM are reasonably close in specs to UESR series like KZG, HM, and MBZ. So for recapping old motherboards with big caps, I think FR and FM is a pretty safe bet. Quote:
![]() Quote:
That said, if the PC you were working on had a GF6100/6150 chipset, expect it to do poorly for HD video acceleration. I rebuilt a system like that with Athlon II X2 215 last week, and it couldn't do 720p video @ 60 FPS very smoothly on YouTube. Added an old GeForce 8600 GT video card in the system, and even that outdated GPU helped off-load the CPU a lot more. Quote:
![]() Sometimes, the best fixes are the most simple ones. ![]() Speaking of which, I just found out that one "dead" mobo I had sitting for years is actually OK. After literally checking everything on it and trying whatnot, I decided to press hard on the CPU socket (s775 BGA). Welp, that did it - mobo POSTed as if nothing was wrong with it. I released pressure from CPU socket area, and it was "dead" again. Repeated once more, just to confirm. Bleh. Screw BGA sockets! |
#935 |
A Fake Rubycon
![]() 4x Sanyo WF 1800uf, 6.3V.
These are on the same motherboard i mentioned in a previous post. |
#936 |
#937 |
City & State: CA.
My Country: USA.
![]() Sanyo’s WF series has issues with long-term reliability. I would not deem Sanyo (Suncon) a bad brand just because of that one series. I’ve seen quite a few ECS motherboards from 2009~2010, loaded with 1800µF 6.3V Sanyo WF and a few 1000µF 6.3V Sanyo WG. The Sanyo WF seem to fail quite often while the WG seem to be okay, along with the rest of the caps. I guess you could chalk this up to the WF being in more stressful locations (on the output of buck regulators, high ripple current duty), but I take it as more of an indication that the WF series is just plain unreliable.
#938 |
![]() I just hope the WFs aren't resleeved Samxon GFs!
#939 | ||
City & State: Northern Germany
My Country: Germany
Line Voltage: 230VAC/50Hz or 400VAC/3P/50Hz
![]() Quote:
The Design is too often overlooked when the Cap goes bad... That Teapo SC go bad in a Flex ATX PSU, after ~7-10 Years should be obvious, shouldn't it? Quote:
That's a General Purpose capacitor... Anyway, LZP is a bit above Teapo SC (wich is/was 2000h in 10mm if downsize IIRC), LZP can be double that. LZG is even better than that and has at a bare minimum 4000h lifetime. |
#940 | ||
City & State: CA.
My Country: USA.
![]() Quote:
Thread Tools | |
