The Hall of Shame - Badcaps Photo Montage
This is a sticky topic.
    Re: The Hall of Shame - Badcaps Photo Montage
    JEE capacitor
    They were found on many generic 300-350W PSU.
      forever...bullshit!
      from an astron rm 50 m psu
        Where'd they use that 85C GP part?
        PeteS in CA
          noname? vent brand?
          I'm affraid that "VENT" is the brand. Seen few in some PSUs, usualy they hold their name and vented
          KILL it with FIRE!
          "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
          "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
            hermei with panasonic vent copy.
              in a astron rm50's board.
              this is a low stress app.
              lm723 and a mess of pass transistors.
                The uA723 is a very old linear regulator IC designed in the mid 70s, by Fairchild IIRC. Obviously, it was a very decent design, since it is still being used. Boschert used to use 723s as PWM controllers in their late 70s, early 80s medium power SMPSs (their two-stage design).
                PeteS in CA
                  nkcon from acer 24" lcd ccfl inverter.
                    A Sam Yong cap, from a Humax CI5100 DVB-S Sat receiver SMPS.
                    It was at the 5v rail, all other voltages where far out of spec, as the bad capacitor does not hood up any voltage anymore.
                      I've just had two PCM-5896 (Skt 7) mobos go down within 3 months of each other.
                      One was "delivered" in Dec-02 and the other in Mar-2004.
                      Both have a pair of blown KZG 1000uf 10V caps.
                      Is this likely to be the "Bad Cap" Problem or a coincidence?
                        Probably a mixture of age and heat. IIRC KZG are only 2000 hour @ 105c caps, so it might just be its time to go. (AFAIK KZG also seem to extremely dislike high temps.)
                        The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
                        I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
                          2006 ost from dell psu
                            oh crap so early huh?
                              Huh, thats may be a bad desing, simply well underated caps or to hot enviroment.
                              I would say usutch Ost should last at least one year or longer, in a decent desinged PSU.
                              Any way, for my personal use, Ost are not something i leave for long in my PSU´s
                                The bulge on that OST cap is hardly noticeable, any novice could easily look at it and think it's still good. But I know from experience that caps don't have to be domed up and spilling their guts out to start showing symptoms! I had a Fujhyyu cap in my PSU that was domed only very slightly (like that OST), and the PC would constantly reboot.
                                I also have some caps that are apparently Fujitsu polymer (although they have a K vent on top). One of them is ever so slightly bulged - could even be manufacturing defect, it's so small. Board is still stable at the moment.
                                You know there's something wrong when you open your PC and it has vented Rubycons...
                                  this is from a dell dimension e310
                                  the psu is 230w and is running a p4 3.4 and lots of drives.
                                  started bootlooping and died.
                                  those ost remind me of a bunch of licon i pulled from a video card a while back.
                                  same greenish gold print and bullseye bung.
                                    Bulged Fujiyuus from an Antec 2 fan PSU.
                                    I found these by luck I just happened to shine my flashlight through the rear fan and decided to check the caps and I spotted a slight bulge. Any novice would think they were fine.
                                    The blue ones are the secondary filter caps which I found after opening it up.
                                    Ironically enough the black caps were right in front of the rear fan (the caps that signaled me to open the supply up) and they still bulged .
                                    Sorry my camera flash obliterated the dielectric if you look closely you should see a bit of it coming out.
                                    Its better to catch them early then catch them late.
                                      FuhTin? bulged capacitors pulled from HP x4000 Workstation memory controller card. 1000uF 10Volt
                                        Might be Fuh Yin. The series name, "PSRX" is reminiscent, IIRC, of NIC Components's "NSRX" series name.
                                        PeteS in CA
                                          Maybe Fuh Kin ????
