Where i can get fresh laptop batteries ?
    Re: Where i can get fresh laptop batteries ?
    Originally posted by ChaosLegionnaire View Post
    i wonder if its easier to just open up the laptop battery casing and just replace the individual cells inside instead? if they use 18650 lithium cells or some other common form factor for lithium batteries, u can replace that instead and u can order and choose good cells from reliable sources. but im not sure if u have to keep the voltage and capacity the same as the original ones to avoid dmging the cells during charging or discharge(normal use).
    as for charging 1000 dollars for shipping, i guess its their polite way of saying they dont ship to your country... try ebay instead... the laptop model should be enuff to get the right battery as most sellers list their batteries according to which laptop model it fits. e.g. most sellers would list their batteries as "hp dv9500 battery" or some such. easier for buyers to find what they want, dont u think?
    Hi again bro . Am back after Corona pandemic.
    How can I bust them open ??
      Best trick is to put a long wooden plate on the thinnest side of the battery and then give it a nice blow with a hammer .
      Some also prefer to heat it from its thinnest side but this way it may damage the plastic covers .
        Use a paint scraper blade something like this
        I know you are not from the USA however if you can find something like this works very well for opening plastic enclosures for battery packs
        https://www.homedepot.com/p/Anvil-2-...996641#overlay
        9 PC LCD Monitor
        6 LCD Flat Screen TV
        1 Dell Mother Board
        15 Computer Power Supply
        All of these had CAPs POOF
          Thanks you everybody.
