Trying to fix ESS based sound card, problems with amplifiers
  • Paar
    • Jun 2020
    • 14
    • Czech Republic
    Hi everyone. I have a problem with my ES1868 based sound card, mainly with it's amplifier part. The right channel is crackling all the time, but only when amplified. When the card is set to LINE OUT, both channels work fine. I have replaced the amplifier chips with new ones but the problem persists (chips are two LM386N1). When there is only right amplifier installed the channel works fine but when there are both, the left is fine but the right crackles. Made some measurements - left amplifier outputs approx. 6V but the right one outputs 12V. The weird thing is that bot GAIN pins on the left amplifier have approx. 1.3V but with the right amplifier one of the chips has 5V-7V and the second one has around 3V and is changing constantly. Is it some voltage noise? Some kind of short? I am not very skilled in fixing audio circuitry so I am searching for help even though I know it's hard to help without having the card personally. The amplifier circuit seems very simple but I cannot figure it out. Has someone experienced something similar?
    I have replaced all electrolytics but that didn't help whatsoever. The problem had to occur by some HW malfunction or overvoltage as the card itself was unmodified when I got it. Where should I start?
  • Paar
    • Jun 2020
    • 14
    • Czech Republic
    Re: Trying to fix ESS based sound card, problems with amplifiers
    It was a bad solder joint, after reflow the card works perfectly.
    • UserXP
      Mackie CR4 amplifier no sound
      by UserXP
      Hi, people.
      I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
      Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
      10-17-2020, 05:06 PM
    • eduaqa
      Amplifier - bad sound when loud sound on bass
      by eduaqa
      I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
      I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer...
      08-06-2022, 11:28 AM
    • benspawn02
      Anthem MRX500 - no sound. R2A15218FP issue??
      by benspawn02
      Dear Electronics Experts:
      I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
      08-12-2023, 04:46 AM
    • Francesc V.
      Tele-master AS-20 amplifier. No output sound, just noise
      by Francesc V.
      Hi:
      I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
      I've checked fuses and all are ok.
      I've continued with capacitors:
      • The main black one should have 4700uF, but it has lost half of its capacity during these years.
      • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
      The 4 transitors are perfect. Desoldered and tested individually.
      There are also components which I don't know exactly what they are....
      02-16-2023, 07:55 AM
    • valente222
      LAPTOP HP 15-DY2059LA / i3-12gen has stability problems in vccpu coils, BUZZING SOUND. ¿Coil whine?
      by valente222
      Hello friends, I just received this equipment, it has a strange hum on the board. The computer works fine, outputs an image and starts Windows. But the problem is when charging the battery, a constant loop to charge. In short, it never charges the battery. When the charger is connected, the stability of the CPU is stressed and it seems that the coils make that electrical sound louder. This board is modern and I don't have a schematic. I have checked with a microscope and the pcb is completely new. Has anyone had this happen to them before? defect in driver ic?...
      11-18-2024, 03:21 PM
