Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 01-20-2022, 12:41 PM   #1
CraigR
CraigR's Avatar
City & State: Wisconsin
My Country: USA
I'm a: Knowledge Seeker
Default Samsung UN55EH6000F Power issue
I got in a Samsung UN55EH6000F with no power and blown fuse on the board (BN44-00499A) I found 3 bad mosfets and a blown resistor circled in the pictures. Now just putting power to the board and checking voltages I get what I need 13v then goes off and on over and over. I connected to TV and TV powers on with sound then off over and over again. I did not include pics of the TV since it is in the power board. So what would cause it to power on and off repeatedly? ?
CraigR is offline   Reply With Quote
Old 01-20-2022, 07:33 PM   #2
nomoresonys
City & State: midwest
My Country: U.S.
Default Re: Samsung UN55EH6000F Power issue
Check all the diodes and touch up any solder joints that look odd.
nomoresonys is online now   Reply With Quote
Old 01-20-2022, 07:36 PM   #3
CraigR
CraigR's Avatar
My Country: USA
Yep, went through all that before posting.
Old 01-20-2022, 07:51 PM   #4
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
That looks like a gate drive resistor, I would check the zener diodes and the other resistors in that drive circuit.
One of the components you have circled is the standby ic, was it replaced as well?
R_J is online now   Reply With Quote
Old 01-20-2022, 08:21 PM   #5
nomoresonys
My Country: U.S.
Quote:
At least a few still look cracked to me.
Old 01-26-2022, 02:08 PM   #6
CraigR
CraigR's Avatar
My Country: USA
Yes, it was replaced also.
Old 01-26-2022, 02:38 PM   #7
CraigR
CraigR's Avatar
My Country: USA
I found this mosfet (2 legs gone now) with nothing going threw it compared to other one with same number. Anybody know how I can get a good number to get another? WR N7 not coming up with anything on google.
Old 01-26-2022, 03:24 PM   #8
R_J
City & State: ☻
My Country: Canada
What is the board location?
Old 01-26-2022, 03:30 PM   #9
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Line Voltage: 120VAC 60Hz
Looks to be an NPN. If it is sot-23
WR 2PD602R Si-npn GP, Sw, 60V, 500mA, 250mW, B=120..240, >160MHz SOT-23
If you have a component tester, just remove the other one and check it.
__________________
dskall is online now   Reply With Quote
Old 01-26-2022, 03:33 PM   #10
diif
City & State: Midlands
My Country: England
diif is online now   Reply With Quote
Old 01-26-2022, 03:47 PM   #11
CraigR
CraigR's Avatar
My Country: USA
Might be 2SK322WR What is the board location?
ZDL802 so must be zener diode and not a mosfet? the N made me think N channel?
Old 01-26-2022, 04:04 PM   #12
lotas
City & State: Sochi
My Country: russia
Bzx84c24-au
lotas is offline   Reply With Quote
Old 01-26-2022, 04:04 PM   #13
R_J
City & State: ☻
My Country: Canada
That looks correct, let me guess, they are in the gate circuit.
Old 01-26-2022, 04:23 PM   #14
lotas
City & State: Sochi
My Country: russia
in the gate circuit
Old 01-27-2022, 01:52 PM   #15
CraigR
CraigR's Avatar
My Country: USA
Yep. Thanks for the number! I will order some up and get back with how it goes.
Old 02-03-2022, 10:48 AM   #16
CraigR
CraigR's Avatar
My Country: USA
UPDATE: Same thing. 13v then zero just keeps doing it over and over. I was looking it all over again and see a tiny crack in the big green thermister wtr15d050 but I get 8.3 ohms cold so not sure if the crack means damage or not?
Old 02-03-2022, 12:39 PM   #17
R_J
City & State: ☻
My Country: Canada
What about the A5V is it changing as well?
Old 02-03-2022, 01:07 PM   #18
CraigR
CraigR's Avatar
My Country: USA
Yes it is.
Old 02-03-2022, 01:39 PM   #19
R_J
City & State: ☻
My Country: Canada
Yes it is.
The first thing I would try is to connect the PS_ON/OFF pin to ground, this should place the power supply in standby mode, then you can see if the standby voltage A5V is stable.
CNM803 pin 14 is PS_ON/OFF
Old 02-03-2022, 02:12 PM   #20
CraigR
CraigR's Avatar
My Country: USA
Zero volts 5 nor 13 when when PS_ON/OFF jumped to ground.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
