Thread Tools | Display Modes |
#1 |
City & State: Melbourne
My Country: Australia
I'm a: Knowledge Seeker
![]() I have a LG RC689D power supply to replace caps but I'm not sure about ripple current values, one cap is 16V 2200uf 105c and I found the two below caps that I'm thinking of getting but do I choose one with a low or high ripple current?
https://au.rs-online.com/web/p/alumi...citors/0374433 and https://au.rs-online.com/web/p/alumi...citors/7037501 |
#2 |
City & State: Midlands
My Country: England
I'm a: Professional Tech
![]() Only one is in stock. Look at the data sheets for the caps you're replacing, they will tell you the ESR and ripple required.
One of the caps you list above isn't in stock. |
#3 |
City & State: Europe
My Country: some shithole run by Israeli agents
![]() ripple current should be equal or higher - never lower than what your replacing.
#4 |
![]() I have looked at the data sheets for two brands "Sam Young" and "Samwha" and I found most of them, the ones below are the ones I found with the ripple current value:
Sam Young: https://www.samyoung.co.kr/product/p..._miniature.asp KMG, 25V, 100uF, -55c ~ +105c, +-20%, 6.3mm (diameter) x 11mm (high) 159 rated ripple current (mArms/105c, 120Hz) KMG, 16V, 100uF, -55c ~ +105c, +-20%, 5mm (diameter) x 11mm (high) 119 rated ripple current (mArms/105c, 120Hz) KMG, 10V, 220uF, -55c ~ +105c, +-20%, 5mm (diameter) x 11mm (high) 170 rated ripple current (mArms/105c, 120Hz) NXB, 16V, 2200uF, -40c ~ +105c, +-20%, 12.5mm (diameter) x 20mm (high) 2,360 rated ripple current (mArms/105c, 120Hz) Samwha: http://www.samwha.com/electric/produ....aspx?f_num=39 SD, 450V, 68uF, -40c ~ +85c, 16mm (diameter) x 35.5mm (high) but cap is 18mm x 32mm 503 ripple current (mA rms) at 85c, 120Hz RD, 25V, 1000uF, -55c ~ +105c, 10mm (diameter) x 20mm (high) 820 ripple current (mA rms) at 105c, 120Hz SD, 10V, 1000uF, -40c ~ +85c, 10mm (diameter) x 12.5mm (high) 659 ripple current (mA rms) at 85c, 120Hz so would I replace the above caps with the same or higher ripple current eg: 820 RC is 820mA (milli amps) RC? But what is 2,360 RC? 2.360 amps? The below caps are the ones I need help to find the ripple current: Sam Young: KMF, 16V, 2200uF, 105c, 13mm (diameter) x 20mm (high) KME, 16V, 2200uF, 105c, 12.5mm (diameter) x 25mm (high) KME, 25V, 470uF, 105c, 10mm (diameter) x 17mm (high) SMS, 35V, 33uF, 85c, 5mm (diameter) x 12mm (high) Samwha: RG, 10v, 1000uF, 105c, 10mm (diameter) x 17mm (high) RG, 50V, 47uF, 105c, 6mm (diameter) x 11mm (high) Someone said to replace all the 10-16 volt caps with 25 volt caps if I do this do I keep the same ripple current or go with something higher but how higher is to high? |
#5 |
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
![]() The NCC KMG series looks to be a high quality 105C general purpose part (and no longer in VCC's catalog?). The Rubycon ZLH series is a very low impedance, long life part. Very different parts for very different applications.
Rather than throwing parts at what you're trying to repair, I suggest understanding how the part you want to replace was used. Maybe start with the manufacturer and series and cross-match that with a similar or slightly better part.
__________________
PeteS in CA Power Supplies should be boring: No loud noises, no bright flashes, and no bad smells. **************************** To kill personal responsibility, initiative or success, punish it by taxing it. To encourage irresponsibility, improvidence, dependence and failure, reward it by subsidizing it. **************************** Anti-Covid-Vaxxer pig crap claim/prediction, Doctor: Heart Failure from mRNA Jabs "Will Kill Most People" | Principia Scientific Intl. ; Dr. Geert Vanden Bossche Warns COVID-19 Jab Injuries and Deaths Will Soon "Collapse Our Health System" (VIDEO) ; Fully Vaxxed May 2021; Since that time I've done 7 5Ks, 1 8K, 8 10Ks, and 4 half marathons |
Thread Tools | |
Display Modes | |
