Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 01-19-2022, 03:45 PM   #1
caprider
City & State: Cluj-Napoca
My Country: Romania
Line Voltage: 234.6V 50.0Hz right now
Default Inductor or resistor
See attachment.
This blown component is connected to the output of a bridge rectifier on a SMPS.
It looks like a resistor (it has colored marking lines), but it is marked as L1 on the PCB, suggesting it is a coil. Which is it?
This is a very basic and cheap SMPS which I am analyzing for learning purposes.
Thanks.
PS: don’t worry, I know there are about 330V after that bridge rectifier IF powered and I take the necessary precautions.
File Type: jpeg 3C1B6C51-B5E3-4BF5-8C93-B3FB2E7CEBE5.jpeg (262.5 KB, 33 views)
File Type: jpeg 25D22FBA-2199-462E-9A72-149A53560437.jpeg (204.5 KB, 24 views)
caprider is offline   Reply With Quote
Old 01-19-2022, 04:09 PM   #2
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Re: Inductor or resistor
Still an inductor probably, they do make inductors like that but the ones that look like this are low inductance and low current handling...
eccerr0r is offline   Reply With Quote
Old 01-19-2022, 04:15 PM   #3
caprider
My Country: Romania
So they are both based on “How to diagnose and fix everything electronics” (attached). But what’s their main purpose: coil or resistor?
File Type: jpeg 4F4B4203-F131-42DA-892C-7C8153306DD0.jpeg (118.5 KB, 9 views)
File Type: jpeg 570ACA2A-8278-4B7D-9DD0-E25A556B0F57.jpeg (70.0 KB, 7 views)
Old 01-19-2022, 04:18 PM   #4
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Coil; probably half ^%%#* way of reducing EMI.
Old 01-19-2022, 04:32 PM   #5
caprider
My Country: Romania
And how many ohms does it have?
I can’t decide if first and last colors are red/brown (maybe orange?).
Old 01-19-2022, 04:48 PM   #6
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
as low as possible...
Old 01-19-2022, 06:51 PM   #7
redwire
City & State: Alberta
My Country: Canada
The part is a ferrite-core inductor used for a differential-mode filter, roughly around 1-5mH. Purpose is to lessen the EMI and RFI noise from the SMPS primary that radiates out to mains. You could read the colour codes for its value.
Cheapest chinese smps and wall-warts don't even have the inductor, they leave it out.
Typically you would see a common-mode choke there but this wall adapter is low power 1.8W output and just a single inductor is used instead.
The part must have got hit/broken somehow.
redwire is offline   Reply With Quote
Old 01-20-2022, 11:56 AM   #8
caprider
My Country: Romania
Thanks. I didn’t know coils have the inductance value color-coded.
Based on lines it’s 1mH.
Can I replace it in this power supply with a coil of 1500uH, 100mA, 25Ω?
Old 01-20-2022, 12:15 PM   #9
faraday28
City & State: Jakarta Pusat
My Country: Indonesia
Basically Coil are inductor because they have inductance value.
Your power supply design is very weird, it usually use with real coil not low powered inductance such as the picture, it blown because it can't hold the heat from current passing through. that's typical cheap power supply, they use wrong parts (cheapest) for easily blown out and you will decide to buy another )
if you unsure, you can bypass it with jumper wire, because line filter (EMI filter) should be after line input. or you can try the 1.5mH, it doesn't do much.
Most cheapest power supply like this use the design without line filter or X cap or Ycap, because they tends to fail and blow up if they buy from cheapest distributor.
faraday28 is offline   Reply With Quote
Old 01-20-2022, 09:19 PM   #10
redwire
My Country: Canada
[...] Can I replace it in this power supply with a coil of 1500uH, 100mA, 25Ω?
That DC resistance is too high at 25Ω, and the current-rating 100mA is too low. You need something with lower resistance and higher current rating.
Badcaps.net Technical Forums © 2003 - 2022
