Corsair HX 450W shuts itself down after a while
  • Paar
    • Jun 2020
    • 14
    • Czech Republic
    Hi. I have bought used Corasir HX 450W power supply and have an annoying problem. I have a PC case with PSU situated on the top of it. Whenever I install this PSU in it and close the cover the computer shuts down after a while. If I let the case open everything is fine. I'm using mATX AM3 motherboard with integrated graphics and am cooling the CPU with big Scythe cooler. With it the CPU idles at circa 40°C/104°F.
    I tried two different PSUs and none of them shows this symptom. The integrated GPU (in the northbridge) gets pretty hot but I'm sure it's not hot enough to overheat the PSU. When I put my hand on the vent side of the PSU I can feel warm air but nothing dramatic. I presume there is something broken inside but I have no idea where to look. Will somebody help me? I have some skill with soldering iron.
    I have attached some photos of the internals of the PSU. Thanks in advance!
    • 30952
    Re: Corsair HX 450W shuts itself down after a while
    i would solder a few wires onto the psu - ground, 5v-standby, and one of the main voltages.
    then hook them to a meter and see which is dropping when it dies.
    go from there.
    because you need to narrow it down.
    btw, did you inspect the back of the board for cracked soldering?
    • Paar
      • Jun 2020
      • 14
      • Czech Republic
      Well I have checked the underside of the board and it looks pristine. Some flux residue but that's that. About testing the voltage rails - you mean I should check both of them (+5V STB and e.g. +12V) with two multimeters and see which rail gets shut down first, that means first which hits 0V?
      I've tried the PSU with another AM3 motherboard and it's the same. I have even tried to use it in my Pentium II machine which is primarily dependant on +5V rail and no shutdown occured. The insides got warm as the CPU hit 40°C and I have Geforce 256 and Voodoo 2 in there, both which are rather on the warm side of cards.
        • 30952
        i would not expect the standby to go down if the main fails,
        but the other way it would because the main psu chips are usually powered from the standby supply.
        to simplify it - just meter the standby voltage
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          whats the voltage printed on the rubycon primary cap? 400v or 420v? cant see from the pics. i wanna bet its the apfc section that focked up and overvolted the primary cap and now the psu is wonky because the primary cap may be partly damaged from apfc overvoltage, so it shuts down during high 12v load.
          • Paar
            • Jun 2020
            • 14
            • Czech Republic
            The voltage is 400V, as seen on the attached photo. Would this problem be affected by case temperature? It seems that higher temperature speeds up the shut down. I have capacitor tester if that helps, I can desolder it and measure it. However it will show me only capacitance and ESR value.
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              Probably silly to ask this, as I'm sure you've checked, but does the PSU fan run when the PSU is upside down? If yes, does the fan appear to spin freely regardless of which orientation you have the PSU in (check by spinning the fan by hand and seeing how long it takes to stop - it should gradually slow down with a "wobble" before it stops and not slow down and stop quickly.)
              Can you also post some pictures of the PSU's PCB solder side? Seasonic (the OEM that built this PSU) has fairly decent soldering, but still worth a check. Also check both the solder joints and the cable connections on the modular PCB.
              • Paar
                • Jun 2020
                • 14
                • Czech Republic
                Yeah I have checked the solder side of the PCB and everything looks fine. I'm attaching a photo so you can see.
                The fan itself spins freely when upside down so that won't be a problem. There must be something else. The seller I have bought the PSU from has another one (650W variant) and when he puts it in a case so the fan is facing the inside, it shuts down too. He contacted Corsair support hoping that they would give us some advice.
                It's just weird that nobody noticed such a problem with this series of PSUs. Probably showed up after some years of use.
                  • 30952
                  you have a cracked solder joint on the main transformer
                  given that they pull on the solder when upside-down, re-solder all of them.
                  • Paar
                    • Jun 2020
                    • 14
                    • Czech Republic
                    Do you see the crack on the picture? Because I have disassembled the whole PSU, inspected the bottom side with magnifying glass and couldn't find any crack.
                      • 30952
                      yes, i see it - pin on the lower left in the photo is pulling out of the solder.
                      trust me - i see things like that long before most other people because i'v seen it so many times.
                      • Paar
                        • Jun 2020
                        • 14
                        • Czech Republic
                        To clarify - are you talking about pins that are circled out, specifically the one with the orange arrow? I cannot see anything there but I'll do as you say and resolder them all, just to be sure.
                          • 30952
                          yes, that one.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8040
                            i'd heat certain things up inside and see what makes it quit.
                            • Quaddro
                              Tukang Kentu
                              • Nov 2010
                              • 141
                              • Indonesia
                              well, based of my experience, if it works but after a while shutdown (not restart), mostly mean a component(s) is overheated.
                              Mostly due to overheated ic.
                              try to replace your 5vsb generator ic.
                              • Paar
                                • Jun 2020
                                • 14
                                • Czech Republic
                                I've tried to open the PSU right after a shutdown and (carefully) placed my finger on every component I could reach. The only thing that produced any kind of warmth was the transformer and even it wasn't so hot it would bother me.
                                I have resoldered the pins of both transformers. Currently I don't have a PC I could test it on but I'll do it as soon as it'll be possible.
                                  master hoarder
                                  • May 2008
                                  • 12170
                                  • Bulgaria
                                  Yes, that might indeed be the case here, since the cooling can vary inside the PSU based on orientation, even if O/P says everything inside the PSU feels cool to the touch.
                                  With that said, we shouldn't jump to the conclusion that it's an IC that is failing, especially the 5VSB IC. IME, ICs rarely fail, unless the PSU was designed poorly... which this one isn't really.
                                  I suggest proceeding next with the tests that sjt suggested in post #4:
                                  https://www.badcaps.net/forum/showpo...37&postcount=4
                                  That is, see if the 5VSB goes out when the PSU shuts down. If the 5VSB circuit goes out, then so will the whole PSU. But if 5VSB is working OK all the time, then the problem is more likely on the main PS somewhere.
                                  Interesting.
                                  I expect the heatsinks should be the hottest parts in a PSU (and they usually are, at least from various PSUs I've tested.) The transformer should not be the hottest part by any means.
                                  Perhaps try power-cycling the PSU and running it on again and again a few times until you can get it a bit hotter. Then see if anything changes inside, in terms of temperature.
                                  • rayfloyd170
                                    • Jun 2015
                                    • 58
                                    • saudi arabia
                                    did you solve this problem by re-soldering the TX terminals?
                                      • Jul 2011
                                      • 6027
                                      What I see is several soldering joints that a lot of flux around the bottom of the joints or on top of the joints but I would also recommend that you put your soldering iron on the soldering joints on the switching power transformer as well you do not always see cracks on the outside of the joints sometimes it is component leads that the cracks appears but are to see
                                      • h0m3w0rk
                                        Random Shutdowns/Startup Failure with Corsair SFX 450
                                        by h0m3w0rk
                                        I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                                        For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                                        02-09-2025, 03:19 AM
                                      • huzo
                                        HP Omen shuts down when loading OS
                                        by huzo
                                        The model is 15ec-1061nm
                                        Board number is DAG3EDMB8D0​
                                        SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                        10-29-2024, 12:05 AM
                                      • chaos-theory
                                        Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                        by chaos-theory
                                        I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                        Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                        03-14-2025, 05:37 PM
                                      • baglaivlad
                                        A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
                                        by baglaivlad
                                        Hello everybody!
                                        Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
                                        After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
                                        11-20-2024, 08:14 AM
                                      • samuelphirik
                                        Dell inspiron 15 7567 sudden shuts down
                                        by samuelphirik
                                        Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
                                        During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
                                        I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
                                        Now I've noticed that laptop...
                                        07-02-2023, 05:45 AM
