Unconfigured Static HTML Module
Static HTML Module Content
HP Envy Recline 23 Schematic - DA0NZ8MB6F0 REV F
    Hi there,
    HP Envy Recline 23 doesn't power up anymore.
    Power supply LED turns of directly after hooking up the plug into the base socket.
    During last usage the back side, top right (near mobo, heatpipes) was really hot.
    Fan was full of dust.
    Disconnected all peripheral connectors (HDD, speakers, HDMI-out, audio, WLAN, etc), only the DCIN cable and FAN cable connected, the power-supply LED still goes out after plugging in the plug into the base.
    Hope you guys have a schematic of motherboard DA0NZ8MB6F0 REV F.
    Or any other suggestion?
    Re: HP Envy Recline 23 Schematic - DA0NZ8MB6F0 REV F
    Supplying power to DCIN (PJ1) + on pin1, GND on pin8.
    Power supply is limiting current to 1A @ 3.7V
    Thermal inspection shows PQ17 (Marking: 4439GM, 40232G) heats up really quickly.
    PQ17 seems to be a MOSFET.
    PQ17 (top side) is close to PU19 (bottom side, marking: AS393M-G1)
    Seems to be: Low Power Low Offset Voltage Dual Comparator.
      Is there maybe someone who knows a board which has a similar design?
      Or someone who has a similar problem?
        Good day
        Please dis u find the schematic or such design??
          hello, I have a computer like this damaged by lightning, it has a couple of burned components near the entrance dc in, specifically r417 and l18
          I leave you an image in case someone can tell me what values they are. thanks.
            Hi - I have one with the same problem. It took me almost 3 hours, but I found PC16 shorted.
              Hi there,
              board view
                R417 = 0 ohm
                L18 = катушка
