Hi All! I've had several successes repairing TVs thanks to the helpful members here. I'm back today with another TV rescued from the curb.
This is a VIZIO M50-C1. Previous owner posted it for free on craigslist with description 'powers on but no picture.' I was unable to get more information from them.
When plugged in, the mainboard LED lights solid purple for 2 seconds, then changes to solid red. As the mainboard LED changes to red, the front LED lights solid white and fades to off over 5 seconds.
When I press power on either the set or the remote, the mainboard LED lights solid purple and the front LED lights solid white. After 10 seconds it fades to dim solid white. After 7 more seconds it fades to off. At this point the set will not respond to power commands from either the set controls or remote.
There is never any backlight activity, and I cannot see any picture using a flashlight.
There is no change to the above when either or both T-Con connectors are unplugged.
I noticed what seems to be a missing screw in the upper left of the main board. Perhaps it was never installed, or perhaps this set has been serviced before. The boards seemed equally dusty and I carefully cleaned them before taking photos. Most of the tape securing the wiring was in place and the connectors are all properly installed so I don't think the previous owner was recently poking around inside.
I've looked over the boards and don't see any obvious faults. I've attached photos of the power, backlight, and main boards. I removed the metal shields covering the right and bottom sides on the main board. I can take more photos if needed.
Thanks for any help you can offer!
