Need help bios Lenovo C40-05 Type F0B5
    Hi guys unsuccessfully updated bios Lenovo C40-05 Type F0B5 MB CFTB351 Ver. 1.0 Now does not start. Can anyone have a working damp.
    Re: Need help bios Lenovo C40-05 Type F0B5
    Post your non working bios backup and serial number .
      Originally posted by smdflea View Post
      post your non working bios backup and serial number .
      s/n p900jc65
        try this one.
          Originally posted by SMDFlea View Post
          try this one.
          Thanks for answering but it didn't work.
            ok ,try again .
              ok ,try again .
              unworked
                I was wrong. Motherboard CFTB3S1 REV: 1.0
                  ok ,try again .
                  Thank you so much. Launched the fifth time with your firmware. Please delete my BIOS dump, there is a working windows key in it.
                    Your bios removed as requested.I`m glad you finally got it working
                      try this one.
                      thankyou, work for me
                        QUESTION: How to use bios.zip to recover bad flash?
                        BIOS update corrupted due to power fail during update.
                        System will not start, and screen is on but blank.
                        Can I reflash using the image in this post?
                        If so, is there a link to the recovery process?
                        I've done bios recovery before (specific USB in specific port, even JTAG) but I can't find anything for these Lenovo models.
                        Serial P9008T9H
                          Serial P9008T9H
                          post the backup copy of the original bios as corrupt as it is ..
                            I have three identical machines. Two worked, one failed. I have no backup bios from the update process.
                            But even if I had a backup, and you supplied a 'corrected' bios, what process would I use to reflash the chip? And could I perform this process with a bios copy from an identical system?
                            I'm missing something about the recovery process, and any explanation of 'how' would be greatly appreciated.
                              you need a SPi Ch341A programmer ..more information and videos can be found on the internet ..
                              https://www.youtube.com/watch?v=DWWigscuQDY
                                Thank you. That was the missing piece.
                                  Hi, Can someone help me update this bios dump ,it's not boot after bios updated?
                                  sn:p9008c3z
                                    sn:p9008c3z
                                    Virgin bios from Lenovo, try it and let me know.
                                    all donations are welcome,
                                      Hi, Can someone help, i have updated the bios and the system not turn on afther flash
                                      sn:p90082R2
                                        sn:p90082R2
                                        Here's your New Bios file, is a Virgin Bios from Lenovo with your DMI and Windows Key. hope it works fine.
