asus x555ld not turn on.
    Re: asus x555ld not turn on.
    Pl9301 0v
    pl8801 2.620v
    pl8101 5.048v
    pl8100 3.300v
    pl8200 1.082v
    pl8003 0v
    pl8501 0v
    pl8502 0v
      All these voltages seem normal. Now unplug the AC adapter and measure resistance to GND on PL8101 and PL8100 and PL8200.
        Pl8101 22.25kohms
        pl8100 256ohms
        pl8200 686.5ohms
          these measurements seem normal so far. Now plug the AC adapter in and measure resistance to GND on PL8101 and PL8100 and PL8200 again. one of these three coils should be shorted.
            Pl8101 0l
            pl8100 ol
            pl8200 ol
              only coils to have ohms to the GND is the coils without voltage...
                was your measurement in post9 with the AC adapter plugged in? If so, unplug the AC adapter and measure resistance on PC9100 again.
                After plugging in and without pressing the power button, how much voltage is on pins of R3093?
                Note: I was not paying enough attention so far. So a few number of the measurements I said, were not required. Sorry. I have to think on multiple mainboards at the same time, so I mix them up sometimes. but now I will help you discover what is wrong on this mainboard.
                  It's okay. I understand and thank
                  the help. I'm not on board now. but pushing the button or not is the same. just by pressing the button for a while it lowers consumption. when released again it has consumption. Does this help? You perceive more and better than I do.
                    X555ld repair guide
                      the board gets reset by pressing the button. so probably, that is why it consumes less for a short period (just maybe). The measurements of Post27 are very important to do tomorrow.
                        Okay. I will make the measurements in the morning and post.
                          from all what I have read so far, I think you have cpu short, if your cpu is onboard then you have to do a replacement by reballing
                            the PC9100 have
                            with AC
                            pin 1 2.066MOHMS
                            pin 2 00.42ohm
                            without AC
                            pin 1 02.56ohms
                            pin 2 00.10ohms
                            R3093 with ac plugin
                            pin 1 000.1mv
                            pin 2 021.9mv
                              someone has bios x550ca
                              mb x550cc rev 2.0
                                mb x550cc rev 2.0
                                see here
                                https://www.badcaps.net/forum/showth...ghlight=x550cc
                                  thanks, look there and they are bios x550cc, I need x550ca.
                                  Thanks for answering.
                                    Originally posted by jp_jota View Post
                                    the PC9100 have
                                    with AC
                                    pin 1 2.066MOHMS
                                    pin 2 00.42ohm
                                    without AC
                                    pin 1 02.56ohms
                                    pin 2 00.10ohms
                                    pin 1 000.1mv
                                    pin 2 021.9mv
                                    HI. I have the same motherboard and the same symptoms. When I connect the charger I have a constant consumption of 0.6A heats the cpu and does nothing, it does the same when I connect the battery. Did you solve it?
                                      I forgot to help @jp_jota after Post33. Probably, I got busy at that time and was away. So I did not see Post33. Sorry.
                                      Dear @MarkosG,
                                      is the 0.6A consumption before pressing the power button? If so, it is too much and you should look for some shorted component on the mainboard.
                                        Dear @MarkosG,
                                        Hello!!! When I connect the charger I have a constant consumption of 0.6 A, heats up the CPU and does not do anything without pressing the power button.
                                        The voltages are correct in coils 3v, 5v, 1.1v in the cpu coil.
                                        I reset the bios and it worked, after turning it off it did not work anymore.
                                          the mainboard gets automatically started without pressing the power button. Now, you should discover what changes whenever you reset the Bios.
