Canon PIXMA MG5650 dump
    Hello all, i have Canon MG5650 with error 5b00 and service mode blocked so i need dump file for the two eeprom chips, please help !
    Re: Canon PIXMA MG5650 dump
    hello
      I have dumped the eeprom from a printer if anyone needs it just ask for it
        give me plz the dump
          hello
          i need this dump file please
            i need this dump too please help
              I'm trying to repair an MG5250, can you send m the dump files ? It may be equivalent...
                Well I'm afraid they are not compatible !
                  This is dump for mg5650
                    thank you so much
                      tanks
                        whats this 2 files how can i use them , or how can i flash them into the board .please any one can help me thanks i have mg5650 and 2 years since 5b00 occurred and still i couldnt fix it please help me thanks...
                          Does anybody have any pre-flashed proms i could acquire?
                          I just bricked my printer and was hoping to save it from the scrap heap!
                          thanks!
                            thanks!
                            RESOLVED! - I was able to reprogramme both chips (without desoldering them) using the images provided using a CH341A + AsProgrammer. Initially the original software I used didnt understand the GD25Q128C properly however switching to ASProgrammer did the trick.
                            nb. the file name for the GD25Q128C image refers to 700 pages usage and not setting the Page setting to 700 in AsPropgrammer.
                            Many thanks guys!
                              Hi guys, After my printer packed up (ink absorber full) I thought I would try and fix it.
                              Thought I had the right software but didn't and it locked me out of service mode.
                              That's when I happened to stumble across this topic
                              So I purchased a CH341A & downloaded AsProgrammer. Managed to flash the MX25CL1636 without any problems but the GD25Q128C is giving me no end of bother.
                              I cant get it to work at all, It wont detect or flash, Sometimes it looks like it is doing something but then just locks up.
                              Strangely sometimes it appears to read but the resulting file is blank. I have tried AsProgrammer, CH241A Programmer & NeoProgrammer.
                              Any advice would be greatly appreciated.
                                I found i needed to unplug the CH341A programmer when i move the chip clip, as otherwise it seemed to not be accurate on read and write operations.
                                  Hi All, I have come across a MG5650 card which has SIP chips which are marked differently to the firmware dump files above.
                                  Do I need the correct chip dumps for these chips or should the above dumps work? (they dont appear to but could be another issue). They seem to programme OK but the card will not initialise.
                                  The chips are marked 25Q16CVSIG & 25Q128FVSG
                                  Any pointers much appreciated !
                                    TRY THIS DUMP
                                    THIS DUMP IS GOOD
                                    password : ISLAM
                                      hello I have a mg5650 with the chips 25Q168SIG and 25Q125C i attemp to flash with mx125l1636e and gdq128C but it doesn't work.
                                      if anyone have the good dump ?
                                        thank you bro
