HP G2 210 X2 - Schematic / Boardview
    I'm looking at a HP G2 210 X2 motherboard (dad91amb6e0 rev e) which isn't charging.
    No obvious visible defects, booting into Linux shows problems around smbus/i2c communications to the charge ic.
    Can't really tell whic ic is resposible, hopefully you guys have any clues, or infos about that board.
    Thanks a lot.
    tdjb
    Re: HP G2 210 X2 - Schematic / Boardview
    Originally posted by tdjb View Post
    hi,
    i'm looking at a hp g2 210 x2 motherboard (dad91amb6e0 rev e) which isn't charging.
    No obvious visible defects, booting into linux shows problems around smbus/i2c communications to the charge ic.
    Thanks a lot.
    Tdjb
      Review the voltage of the I2C / smbus lines on the battery connector. Often there are local esd diodes that get damaged - that is their job if a transient is hit on the battery area. This damage leads to the I2C lines being stuck due to the damaged esd parts.
        Oh wow, thank you so much.
        Now I only need to find some time to actually look into it again.
