Dell Inspiron 15 5577 DAAM9BMBAD0 REV D
    Re: Dell Inspiron 15 5577 DAAM9BMBAD0 REV D
    Will this work with Dell Inspiron 15 5577 DAAM9BPIAD0 REV D?
    If not, how do I request that bios dump?
    I'm a newbie on this forum.
    Thanks.
      Make backup of your bios dump
      And flash with given bios above from post #1
      If no luck than post your backup here some one will fix your bios issue
      Always post complete details of your laptop model number, motherboard part number with attach bios file
        Sorry, the part number I posted was that of the audio board.
        The motherboard has the same part number as in the thread title.
        There are 2 files in the zip(8KB and 4KB in size), which one should I use?
        There are also 2 chips on the motherboard, both Winbond - 25Q64JVSIQ and 25Q32JVSIQ. Please let me know. Thanks!
          Working.....thanks man
            Thank you!
              Dell Inspiron 15 5577 DAAM9BMBAD0 REV D PLEASE CLEAR ME
              Pls clear me bios
              thanks
                Re: Dell Inspiron 15 5577 DAAM9BMBAD0 REV D PLEASE CLEAR ME
                Originally posted by SR IT SOLUTION View Post
                Pls clear me bios
                thanks
                But this bios is configured !!
                where's your own bios dump
                  Pls clear me region dell bios 15-5577
                  HI ALL PLEASE CLEAR ME REGION BIOS
                  MODEL NO DELL 15-5577
                  PART NO : daam9bmad0 rev
                  service tag number:-2364rh2
                  here is org. bios dump or
                  serial number downloaded bios
                  thanks in advanced
                    (a7) me fw downgrade - request mespilock failed dell
                    error showing and off system
                    pls help
                      Re: Pls clear me region dell bios 15-5577
                      thanks in advanced
                      This is clean me of your 2 dump , 4+8 Mbytes.
                        try this i clean the me region
                          thanku so much for your help!!
                          but display not coming when i flash this bios..
                            i just clear me your files for this Inspiron 15 Gaming ...did you try a good known ram , did you separate the cmos from motherboard when power on !!
                              yes i replace ram many times, and cmos also removed.
                                try this again
                                  Originally posted by alfredposadas09 View Post
                                  try this again
                                  thanks for your help!!!!
                                  but not working
                                    I need bios for my service tag: 60bnrm2 and old backup file also attached. Anyone can help me
                                    thank you
                                      I need this bios, anyone can help me
                                        try.
