Badcaps.net Forum
Go Back   Badcaps Forums > Welcome to the Badcaps.net Tech Forum! > Frequently Asked Questions (No Posting)
Thread Tools Display Modes
Old 05-01-2005, 05:50 AM   #1
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
Default Different Types of Capacitor Mounting
There are several different types of capacitor mounting configurations and also capacitor types. The most common type for motherboard applications is radial lead/radial wire ended.
Aluminium Electrolytic Capacitors - Radial Lead
An example : Panasonic FC capacitors which are radial lead. This means that they have two leads + and - coming out of the capacitor on the same end. The negative lead is the shorter one and also indicated by the stripe down the side of the capacitor which also shows a - symbol, repeated along the length of the capacitor. The photo shows capacitors as you would receive them new with the full length of leads that you can cut to size. These capacitors are Aluminium Electrolytic which means that there is probably two layers of aluminium foil which are separated by paper that is impregrated with an electrolyte gel. The layers are then wound and enclosed in an aluminium or plastic tube. You can clearly see in the photo the capacitor bungs at the bottom of the capacitor. On good capacitors like the Panasonic FC they are made of EPT (Ethylene Propylene Rubber) which is a synthetic material. On the bad capacitors for cost reasons, natural rubber is used. This gets hard with age and the failure of the electrolyte can bust the bung out of the bottom of the cheap caps, leaking electrolyte on your nice smd components.
Axial Lead
This means that one lead is at each end of the capacitor.
Surface Mount Chip Type Capacitors
Surface mount chip capacitors on an Asus video card. See their black surface mount seats which are at the bottom of each cap. The black mark on the silver top of the cap indicates the negative lead. The seat is also square at the negative side. It is not clearly apparent from the markings, who manufactured these caps. Why would they use these surface mount chip capacitors instead of normal radial lead capacitors? Well it is easier to place and solder them to the board with machines.
__________________
willawake is offline   Reply With Quote
Old 05-01-2005, 10:07 AM   #2
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
Default
Surface Mount Capacitors
Very small components which are soldered to one side of the board, either at the front or the back.
The above image shows the ceramic smd capacitors positions with the numbers preceded with CB or C. The resistors position numbers are preceded with R.
Old 05-01-2005, 10:56 AM   #3
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
Default
Surface Mount Tantalum Capacitors
As indicated by the orange arrows. They come in case sizes A,B,C,D,E. The small ones in the photograph are B and the larger one is D. The bar on the cap indicates the POSITIVE side. These were used in motherboards, graphics cards, lan cards etc. I did not see them used after geforce1 though.
Old 05-01-2005, 01:44 PM   #4
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
Default
need help with this thread guys....
Old 06-07-2005, 07:53 AM   #5
TheInfamousJerry
Default Re: Different Types of Capacitor Mounting
Free-Standing Capacitors
These are very popular among AMD users. These suckers will power up to an Athlon XP 2400! Installation is simple, bolt the capacitor to the side of your case, preferrably with a U-bracket and weld the leads to the most convenient and accessable area!
Note: Don't do this! This post was merely a joke! Neither me nor the board moderator nor owner should be held responsible if you wire a huge capacitor to your board, rendering it(and probably yourself) inoperable!
I helped!
TheInfamousJerry is offline   Reply With Quote
Old 06-07-2005, 07:58 AM   #6
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
I'm a: Professional Tech
all jokes aside those large screw terminal types are commonly called computer grade.
my imsai 8080 has 2 of them.
the smaller ones in the center are snap ins.
used in some pc psu.
I helped!
kc8adu is offline   Reply With Quote
Old 10-02-2005, 10:15 AM   #7
arneson
City & State: SWF
Why the disclaimer saying not to do this?
It's not merely a joke.
I have lined the inside of my case with these big boys and she's stable.
But it takes an hour for the power light to go off.
arneson is offline   Reply With Quote
Old 10-02-2005, 01:48 PM   #8
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
One of the nicknames for a computer grade types is a "beer can" (though some are more the size of a V8 juice can. Some larger snap-ins have an extra terminal or two to improve mechanical stability.
__________________
PeteS in CA
Anti-Covid-Vaxxer pig crap claim/prediction, Doctor: Heart Failure from mRNA Jabs "Will Kill Most People" | Principia Scientific Intl. ; Dr. Geert Vanden Bossche Warns COVID-19 Jab Injuries and Deaths Will Soon "Collapse Our Health System" (VIDEO) ; Fully Vaxxed May 2021; Since that time I've done 13 5Ks, 1 8K, 12 10Ks, and 4 half marathons
PeteS in CA is offline   Reply With Quote
Old 10-17-2005, 09:11 PM   #9
OldeCrow
if you don't want to power your computer with them they are fun at parties too
OldeCrow is offline   Reply With Quote
Old 05-19-2006, 10:51 PM   #10
triplelatte
triplelatte's Avatar
City & State: Ohio,USA
My Country: USA
I'm a: Knowledge Seeker
I have something close to that in the trunk of my car. I use them to store power for my amps so when the bass hits my light don't dim. the brand is lightning caps and they pack a punch to them. a friend of mine damn near blew his hand off messing with his .
triplelatte is offline   Reply With Quote
Old 06-13-2008, 05:40 AM   #11
Gendo Ikari
I accidentally knocked one of these off an old ISA 10Mb network card I got from a guy. I was wondering what the heck it was. At least I can maybe replace it now if I really want too.
Gendo Ikari is offline   Reply With Quote
Old 06-13-2008, 07:20 AM   #12
gonzo0815
City & State: Germany
Tantalum capacitors.
gonzo0815 is offline   Reply With Quote
Old 01-02-2015, 11:54 PM   #13
Moopy
City & State: Pine Bluff, Arkansas
My Country: United States
I'm new here and was looking for a nice spot for my first post and stumbled across this thread of knowledge. I've seen tons of these types of capacitors but I never knew their technical names. Now I just need to learn about diodes.
Moopy is offline   Reply With Quote
Old 06-24-2015, 03:12 AM   #14
jentoris
City & State: West Java
My Country: Indonesia
Line Voltage: 220VAC 60Hz
that yellow capacitor is the smaller size of caps and give you the most stabel power output than the other caps pictured, and also it's more expensive.
jentoris is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2023
Powered by vBulletin ®
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
