Weller WD1 with T12 Tips
    Dear BC,
    Today, by luck & chance I found a used Weller WD1 soldering station in my used local market for a very good price and I couldn't say no
    The seller sold it as it's with no warranty and no return, I accepted his t&c since he gave it on my asking price, only the station nothing else with
    My question, is there a way to mod a T12 with this station or someone did like this modification before
    Thank & waiting your replies
    Re: Weller WD1 with T12 Tips
    Hi again,
    I found Weller EC1301 iron handle 5 pin, and I have Weller WD1 station
    I found the 5 pin diagram for the iron handle:
    Pin 1:- Grey - Element High From Transformer 24V
    Pin 2:- Grey - Element Low to Diode/Triac
    Pin 3:- White - Thermistor High to Adjustment Pot'r
    Pin 4:- Purple - Thermistor Low to LF353 + input circuit
    Pin 5:- Black - Earth to Tip/Barrel
    I want to find a way to join the 7 pin station with the 5 pin handle
    Please advise
      Hello guys
      Any help to offer
        i dont know if the sensors are the same,
        there is/was a guy who built a universal soldering controller and had documented a lot of different hand pieces.
        http://dangerousprototypes.com/forum...p?topic=7218.0
        what you need to find out is 2 things,
        does the original iron use a PTC resistor or a thermocouple that generates voltage.
        and if it is a thermocouple, is it in series with the heater or does it have seperate connections.
        T12 uses an inline thermocouple,
        weller used to use thermisters - dont know if they still do though.
