Small and robust multimeter probes
    Hello, I search a new probes for measuring pin of qfn and other very small stuffs. I bought the AE basics ones, but they are no longer sharp. Metal is bad. Do you have a stonger ones ?
    Re: Small and robust multimeter probes
    These are good. https://www.aliexpress.com/item/1005004412501876.html
      With replaceable tips, that seams good, thanks
        I didn't see that last photo, the tips aren't replaceable.
          Certain ? Can you check if it the same model number, and try to pull hard ? Maybe that very adjusted ? Or maybe it is a new model ?
            I use fluke 8845A for many years, pomona 6343 is also a good reference
              Yes they areā€¦ at least on the set I have. I recommend you order the leads and spare tips as a pack.
