I bought a SOP8 apparatus for CH341A but zero document. What is this part for and may I use it to read and write to 25 series spi flash bios?
What for this SOP8 apparatus?
Re: What for this SOP8 apparatus?
Originally posted by Kemer View PostThank you but when do we use these? May I use it for laptop bios chip programming?
This piece is used when you want connect soic-8 clip with programmer ziff socket, both side have pins that fit to. I connect this once and never disconnect from clip.Last edited by harp; 05-21-2023, 07:11 PM.
Originally posted by harp View PostYes, but it is recomended to desolder chip first from pcb. You can try read chip onboard, and if fail just desolder it.
Desoldering and re-soldering the bios chip is risky for me. I only have a soldering iron. The clip, on the other hand, is constantly sliding off the chip. The latch design is a lousy idea.
Thank you.
Originally posted by Kemer View PostI have 3 small pcb at the moment. One came out of the ch341 package and two from the sop8 clips package. It should have been specified what they were used for.
It is adapters for conection between either ziff and soic-8 clip, or ziff and bios chip soldered directly to adapter pcb.
Clip shoud fit only to specific soic8, sop8 package, but must be flat to pcb and straight. Plastics claw hold chip underneath, next to pcb board, sliding off is not posible happen if claw is not damaged or wrongly placed.
BTW, you can desoldered soic8 package from pcb using soldering iron, just make some pretinned thick wire formed to rectangular ring that meet to touch all chip legs, than fill all with solder and when melted lift up chip... just first try to some scrap pcb to get experiance.
And BTW2, when useing clip and adapters, wires etc, pay special attention to orientation of chip legs - pin#1 (marked with small dot) must be connected to specific place on programmer. On ch341a is a two different place for 24xx and 25xx chips.Last edited by harp; 05-22-2023, 12:37 PM.
Originally posted by harp View PostAre you absolutely sure you're using your clip specifically in the soic-8 bios package and not in another package like wson8-mlf8-dfn8-tdfn8-qfn8-dip8?
Originally posted by harp View PostPlastics claw hold chip underneath, next to pcb board, sliding off is not posible happen if claw is not damaged or wrongly placed.
Originally posted by harp View PostBTW, you can desoldered soic8 package from pcb using soldering iron, just make some pretinned thick wire formed to rectangular ring that meet to touch all chip legs, than fill all with solder and when melted lift up chip... just first try to some scrap pcb to get experiance.
Again thank you for your time.
the problem with this soic8 clip is they come with too strong loaded spring. In mechanic point of view, I choose as light spring as possible, just to hold clip in place. Any spring can bent inter contact pin for good contact, and no bigger force can ensure better contact, only have stronger grip with package, and much more force necessery lead to gnaw off and to wear out plastics claw quickly...
https://dzrmo.wordpress.com/2017/07/04/chinese-soic-8-test-clips-for-in-circuit-programming-part-2/Last edited by harp; 05-25-2023, 06:36 AM.
Originally posted by stj View Postthe problem with soic8 chips is they come in 2 widths, and the difference is enough to make those clips tricky to use on the wide version.
Originally posted by harp View Postthe problem with this soic8 clip is they come with too strong loaded spring. In mechanic point of view, I choose as light spring as possible, just to hold clip in place. Any spring can bent inter contact pin for good contact, and no bigger force can ensure better contact, only have stronger grip with package, and much more force necessery lead to gnaw off and to wear out plastics claw quickly...
Your opinion on strong loaded spring seemed appropriate to me as well. The chip legs look a little squashed.
I suppose, would do it in the form of a frame instead of that clip. It's hard to describe but I'd seen an adapter plugged into the programmer. It was locking when pushed the chip in. It would be something like this but with a much more thin frame.
I also would add a led for each contact. Maybe I exaggerated a bit, but it would be nice.
I wish I knew these earlier. Thank you again.
And here it is!
How to save SOIC8 clip from wearing, when using on SOP-8W BIOS package...
https://www.youtube.com/watch?v=SrAzVT1OKEA
If the clip was designed better (longer gap below legs - longer free space to stretch) this is not be necesary, and will be compatibile witc soic8 normal and wide package.
https://www.youtube.com/watch?v=bAlwiAeVVgM
You can do that trick on what ever package find (with exposed legs) and you can use a thin wire also, wraped many time around and soaked with tin... principe is the same.
Or use piece of used soldering wick, it is flexible and thick together, even prepared with tin to use out the box...
Thank you, I am glad to hear that
2.5mm is to big. I use 1.5mm for "rectangle O ring" or 1.0mm for "loop soldering iron tip" copper wire. You may do some other form, U, C, M, Z... specific to your case, that fit on particular space in pcb...
The spring is from hp inkjet printer.
I always try to present full idea on video independent of understanding some language. Just look to see point, and brain will do rest
