I have a model ONC18TV001 made for Walmart. I was hoping maybe someone has a schematic or can help me with an IC part number. The LED driver IC has failed. I cannot read the marking on the IC. Looks like a 10 pin msop package. Thank you.
Onn Tv made for Walmart
Re: Onn Tv made for Walmart
Originally posted by sirentech View PostI have a model ONC18TV001 made for Walmart. I was hoping maybe someone has a schematic or can help me with an IC part number. The LED driver IC has failed. I cannot read the marking on the IC. Looks like a 10 pin msop package. Thank you.
I will try to clean it off. Thank you again. The LED backlights are completely removed and there was a short across an smd diode on the power supply board. I took it out and it tested fine. I traced both sides of the diode as best as possible and it appeared to go back to the LED driver IC.
I will reply back with my cleaning job.Last edited by sirentech; 05-14-2021, 06:21 PM.
This is the possible pinout for the iC
Edit
But it doesn't match the information on another site that appears to be as R_J suggests.
https://repowebapps.blogspot.com/202...verter-by.htmlLast edited by dick_barton; 05-15-2021, 05:28 AM.Willing to help but I'm no expert.
