TV not powering on - with standby red –led flashing
    Error – TV not powering on - with standby red –led flashing
    Model- LEDTV – 39T3500
    Power boarD - shg3206a-101h
    I have read through the Basic LCD TV and Monitor troubleshooting guides.
    https://www.badcaps.net/forum/showthr...956#post305956, I am no ELEC engineer but can use a multi meter and soldering iron
    In the meantime I could not see any damage to any caps on the cold side of the power board, so I have replaced all of them.
    Unplugged the power connector on the board, I plugged the power cable in waited 30sec, plugged the connector back. The standby led remained on constant which showed me that it would power on..voila and it worked and we used it for longer than 2 hours. When I switched it off for longer than 40sec still in standby mode, it's flashing again and It would not power on, I had to disconnect the power connector again and got it to power up.
    Then we left it overnight in standby mode, even if I disconnect the power connector and plug it back in again it still stays on a flashing standby led – it does not want to power on anymore.
    I have measured the volts on pin- out's, with the gnd – poweron, bridged, I only get the 3.3v on both the rows, nothing for the 24v
    The power connector is divided in two rows
    DIM H-On….?
    GND P-On…bridged
    3.3v 3.3v….give me 3.3v
    GND 24V…..nothing
    24v 24v....nothing
    What gave up as it did work before and now nothing again, what else can I look at, don't see any visual signs off blown caps as they are all still brand new just replaced them, cant give a high resolution pic now only a crappy low resolution from the web.
    If anyone can give some advice, assistance would be appreciated
    Re: TV not powering on - with standby red –led flashing
    If you can post some photo's of your boards using the attachmnet would help.
      I am not currently home, thought I could get some interaction while I get time to submit them later, much appreciated will upload later
        pics uploaded also the diagram
          Disconnect the mainboard and use a 1K resistor and jumper between pin10 (P-ON) and Pin 7 or 8 (3.3V) and see if your 24V comes up
          Use another 1K resistor and jumper Pin 7 or 8 (3.3V) to pin 12 (BL-ON) to see if the backlights come on. All on CON3.
          The backlights also need the 24V supply to be working.
            What is the purpose for using the resistor, if you only bridge the pins out without the resistor what will happen
            ns...I have no electronic background skills hence my question
              If you were to make a mistake and connect between or to a wrong pin then you could damage the power supply. Example if you connected the 3.3V to ground then you may well have badly damageg the power supply. If you were using a 1K reistor then no damage would happen because the 1K resistor limits the current from the 3.3V supply to 3.3mA
              (3.3V/1K = 3.3mA)
                I have done this and it returned 0 results nothing happens
                  Check this thread out.
                  https://www.badcaps.net/forum/showth...48#post1022048
                  Another model though but it seems to be a similar problem.
                  I finally found a bad chip (MP2363DN).
                  Seems to be a common problem on Samsung TVs.
                  /Chrille
                    With the power supply disconnected from the main board. You have 3.3v standby so you should have +24v at L1 (jumper wire) If you do then connect P-on pin to 3.3v standby and see if you get +24v on Con3 pin 1,2 or 4
                      I have bridged out the 3.3v and the P-On pins, then measured the volt readings on pin1, 2,4 and there is nothing.
                      Like you have explained with the power cord removed I still only have the 3.4v in standby.
                        What voltage do you have on the D(rain), G(ate), S(ource) pins of Q2 in standby and then when out of standby when you jumper P-ON to 3.3V using the 1K resistor
                          Hell for the heck of me I cant find Q2 on the board I only see Q4 is it that thing under the big heatsinks there are 2, which one of them....think I found something on the board but there is nothing mounted
                            The components may be on the other side of the board. Post a photo.
                            What voltage do you have at L1 to chassis.
                              Aha...see when you know your trade you know your stuff found it
                              this is a pic taken earlier as i am not at home to check the v ,,,
                              will do so and report back.
                                I will add the rest of the powerboard in a few pics split up to see better, kindly indicate where to find L1 and how to measure it with the multimeter ( where must I put the red and black leads )
                                You make me sound stupid - but I know nada of these electronic stuff
                                  L1 is shown in the photo in post #13
                                  Red meter lead on L1, black on chassis. Meter set to 20V DC
                                    8v
                                      In and out of standby the voltage fluctuates from 7.5v to 8.3v
                                        V at the jumper wire fluctuates at 7.5 v - 8v,, when on standby or not , still zero volts on the 24v pins
