Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 05-13-2021, 07:41 AM   #1
Storyteller12
City & State: Virginia
My Country: USA
I'm a: Knowledge Seeker
Default Samsung Soundbar No Power
Hi, need some help here.
I have this smps for a n850 Samsung Soundbar that gets no output voltage.
I have check everything and found that Iím getting 390v from the main caps on the hot side. However there is an IC that needs 300v to turn on. There are (2)513 smd resistors in parallel that are supposed to drop the voltage from 390v to 300v. However the resistors drop the voltage to 190v through the first resistor and to 25v through the second.
I took both resistors out of circuit and both measure good 50kohms.
I plan on replacing them anyways but not sure that will solve the problem since they tested good.
Any thoughts or suggestions would be greatly appreciated. In the last picture I highlight the path to the resistors and ic I was talking about
Thanks in advance
Storyteller12 is offline   Reply With Quote
Old 05-13-2021, 06:19 PM   #2
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: Samsung Soundbar No Power
How are you getting 390 volts on the main caps? I don't see a pfc circuit and the caps seem to be straight off the bridge rectifier, so it should be around 160vdc
The ic needs a VCC voltage, this will be across the small electrolytic next to the mosfet heatsink, If this cap is bad, the circuit will not start up.
R_J is offline   Reply With Quote
Old 05-14-2021, 01:24 AM   #3
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I would first replace the [email protected] volt cap and go from there but really you should just replace all the caps good quality caps and go from there except the two main filtering caps unless they are leaking then replace all of them
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 05-15-2021, 07:05 AM   #4
Storyteller12
My Country: USA
Thanks for all the reply’s. R_J you were right about the voltage. My multimeter was acting up and had to replace it.
Turns out it was the ic that was bad and stuck open. I have a new one ordered and just waiting for it to arrive.
The soundbar is fairly new. Only 2 years old so I don’t think the Caps need replaced but since I have it open I might as well right? What brand caps do you recommend?
Thanks again for the help
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
