Bench power supply current stuck at 9 amps
    Hi guys I've got Longwei bench power supply the problem is the current is stuck on 9 amps no matter how I turn the current nob to decrease the amps is stuck on 9 amps and the led indicator for current doesn't turn on. If anyone knows what could be the problem Please i need your help cause the voltage nob is working fine I can increase and reduce the voltage without a problem. Thank you
    Re: Bench power supply current stuck at 9 amps
    I vaguely recall someone else posting about this on these forums but don't remember.
    possibly the current sense resistor fried or I vaguely recall someone having the current pot burned or something... but pictures would be helpful...
