diy hakko t12
    diy hakko t12
    I'm interested in this object
    https://www.ebay.it/itm/Digital-Sold...kAAOSww3tY3-v2
    but is the thermocouple stored in the tip that can be changed?
    Re: diy hakko t12
    yes, thermocouple and element are both in the tip.
    but that kit is rubbish.
    this is better:
    https://www.aliexpress.com/item/MINI...839523934.html
    you even get a case, dont forget to select which tip you want.
    btw, the handle is shit - so you should also grab this.
    https://www.aliexpress.com/item/SHEV...835065313.html
      Re: diy hakko t12
      63.90+7.90 for atten 8586. use if from years and always work fine. just had to replace once the thermocouple for few euros.
      add some extra tips and ur done for every work.
      buy good, buy once.
        Re: diy hakko t12
        but the iron is shit,
        and you can get the hot air unit on it's own - 858D for about 30 on ebay.
          Re: diy hakko t12
          for some years I'm using a Lukey 852D without any problem but with this type of soldering stations the thermocouple is placed directly on the heating element and I almost always use it with the temperature at max.
