help repairing Gigabyte gv-n105toc-4gd
    hi
    im looking for people who have the gv-n105toc-4gd gigabyte
    to look for those components
    shematic and boardview welcome
    need to know those values
    c 671 678 684 693 815 825 824
    r 634
    ty
    Last edited by SMDFlea; 03-28-2022, 05:48 AM. Reason: Renamed thread title from "help repairing"
    Re: help repairing Gigabyte gv-n105toc-4gd
    Capacitors should be 0.22u 6.3v on the pcie lines
    Are you sure it's r634? Looks like c825 that's missing on the 2nd image or is r634 open circuit?
      thanks
      ure right but wanted to know the value just to test and verify...
      825 is missing
      possible same value than 824 ?
      will change the 3 capacitors
      wanted to change them but my iron heater is not adapted too
      so i wait my air thermal to do the job
        This boardview should work
          hi
          im really glad
          as i suposed same model except ram values
          normally got all to maintain it !!!
            Yeah, that circuit looks identical
              hi
              ty again
              just a question how to identify by see the value of voltage of cms capa ?
              must find replacement on "giving cards"
                If it doesn't say then you need to guess from the circuit that they are part of and allow some room for error - what voltages are expected on the inputs etc.
                For instance, C825 shows as being connected to 12V_EXT6 and GND, so the cap needs to at least work with 12v (so aim for 16V)
                  well ty for answer but wasnt the point of the question lol
                  how to reconize a 6.3v than a 16v cause no marks on it ?
                  just the size ?
                  other question is what temperature components supports ? i suppose heavy ones not to burn on rohs....
                  and should be high cause made on ceramic
                  in other hand what temperature ti use to dismount them by air and what on iron to mount them
                  ty
                    Ah sorry, I misunderstood.
                    If you are pulling components from another board then it would be helpful to have a schematic for that board as well, otherwise its hard to know.
                      thanks...
                      they could do differents colours !!!!
                      i recover comonents from many boards....from differents functions.... so dont have any shema
                      other question
                      does c674 678 684 693 missing makes the pc unbootable ?
                      this card is strange...
                      no booting pc but if u does it by motherboard chipset u can turn it on by windows perephicals (dismount and remount)
                      my daughter said she saw like a flash gpu side and near outputs...
                      i suspect her adaptor hdmi->vga to had a pb and makes a component blow
                      l19 seems to get hot
                      and c822 seems to have a crack on it
                      will try a photo
                        here they are
                          perhaps a short on q13 or q14
                            r7093 et 7094 are fine
                            i will dismount l19
                            when i mesure between the 2 sides goes 1 execpt at 1 point goes 0
                            think maybe the solder broken at 1 side
                            it will explain the flash...
                              maybe ure right the 6508 seems to get hot
                              some marks around
                              gonna do a picture to get your pov
                              continuity around l19 and c822 seems ok
                              will redo solder for L19
                                q13
                                how may i verify it ?
                                  Hi!
                                  I´m try this boardview but isn´t valid to my graphic card.
                                  I have gv-n105tg1 4gd.
                                  Some parts are similar, but the part I need is not quite valid.
                                  In my case, the fans and the fan stop led do not work.
                                  Is it possible to get the board view?
                                  Thanks!
                                    Originally posted by nvidiauser View Post
                                    Hi!
                                    Thanks!
                                    hi
                                    otherhands does the card works ?
                                    if it does u can try to reflash the card...
                                    did u try msi afterburner and try to use your own def for fans ?
                                      Originally posted by klendatu View Post
                                      q13
                                      ok found how to test it
                                      so ive got 1.3Mo beetween 3-4 pins
                                      so the mosfet is good
                                      am i right ?
                                      im quite sure the unworking of that card is only missing capa at pcie rail.....
                                      just waiting a capa test to find some to put in place
                                        q14 got 1.7Mo
