Well this one didn't last long....
https://www.badcaps.net/forum/showpo...&postcount=872
We had some severe weather pass though late fall and it got jolted.....got through multiple surge protection devices and got the NIC. I stuck a PCIe NIC in it....but it just hasn't acted right since......but I've been limping it along. I decided it's time to start working up a replacement.
First up is the case.....this came from the shop I cleaned out last October. This is an Enlight built server case OEM'd for Intel....and rebadged by Nobilis.
This is a magnificent eATX case, very thick steel and very heavy old iron server case from 2005.
6 bay hotswap bays...SCSI for now.
Rear shot.
Some intel dual skt604 server board...
Found in another box from the same shop....containing the SATA/SAS backplane needed to make the hotswap bays compatible with such. Lucky me!!
What will replace the IDE CDROM, the floppy, and the SCSI DAT drive.
Dismantling the case.
4x 73gb SCA drives and 2 with the dummy trays.
SCA backplane to be removed & replaced with the SATA one.
Motherboard coming out....
hotswap cage out first...
Air guides removed.
Pile growing...
The big worthless board....
Case empty.
The power LED & switch panel. This uses a flat ribbon cable proprietary to the board. I'll have to re-engineer this for use with standard wires....no problem.
As for what's going in this, it's still in development....but I will reveal that it won't be as per my norm; a dual socket. It'll be a single....I don't need massive computing power at home....I don't do much with it but just basic stuff that we all do...web, office, and some light gaming...but the fun is to come!!
Rear shot.
Air guides removed.
Pile growing...
Case empty.
