Asrock G41M-VS3 R2.0 - repair journey
    Hello again!
    I got this board but no power on. Tested the usual.
    https://asrock.com/mb/intel/g41m-vs3%20r2.0/
    Shorts on +5VSB/+5V/+3V at ATX. 0.7 ohm, not 0. Something is shorting all 3.
    Checked all the components after plugging PSU and found that the SB was very hot but bearable. Another smd, LM1117, responsible for the +3VSB to SB was instead ubearably hot (stick a finger and instantly feel the pain, warming everything in a 1/2 inch radius). I swapped it with another known working LM but still the same.
    Legs have the following readings: +5VSB ok, +3VSB 1.8V - not ok, third leg not ok either. Something was pulling V from the +3VSB.
    https://www.alldatasheet.com/datashe...MI/LM1117.html
    Desoldered LM1117 and the SB would just get warm, there's my short.
    My question: is the tiny ICH7 easy to desolder with just a heatgun? I'd like to experiment desoldering and maybe resoldering one from another dead board, and confirm it is the culprit.
    Thanks for any help!
    Btw, I have the schematics if anyone needs them. Or just look up for Asrock schematic diagrams.
    Re: Asrock G41M-VS3 R2.0 - repair journey
    No repair for this one.
    I desoldered the southbridge and the shorts went away. A heatgun with preheat from bottom worked. It took like 5 minutes though, sounding like chip killer having to go up to 350°C to actually remove it.
    A few pads came off but they were NC or GND. like 6/7 in all. Not bad for a first time.
    It's not economical to replace it, let alone doing the job on the no-room placement of the chip.
    Now it's a donor board for what's on it.
    Really interested in knowing how it could have happened.
