This build was a bit of a spontaneous one. Someone dropped this off for recycling a while back. HDD's destroyed as per customer request. It was in working condition, I just didn't really know what I was going to do with it. It's a Xeon E5-1220 v3 @ 3.1GHz w/ 8gb RAM....nothing too exciting, no CPU support more than 4 cores and max RAM is 32gb. The case is decently built though.
This Lenovo TS440 was just full of things that absolutely annoyed the shit out of me.
First up, a micro ATX motherboard in a case made to hold an eATX! WTF! Second, a proprietary PSU with non-standard electrical connectors... We'll just see about all this sillyness!!
Enter in the new innards, a X9DAi I've had for a while.
Installing in this case won't be the tricky part of this build; as this case was made to take an eATX. Repositioned the standoffs and in it goes!
Midplane fan mounts were my biggest concern, but they cleared by a decent amount.
Don't mind the fan wires, that was just a test fit. They tucked away nice and overall this was a stellar fit in this case.
IO shield.
Now for the power supply.... I couldn't use the one that came with this system.....it was not an ATX by electrical standards (idiotic)....so enter in a Dell D850EF 850W Modular that came out of an Alienware Aurora that had a bad motherboard.
Installed and a K5500 GPU added, it's the best GPU I've got laying around loose right now.
Now to test fire this.....
Booted to Hiren's.
Looks kinda cute!
The PSU cables were short, but a nice fit for this case, everything reached......
Ok, I know what you're thinking....this one went way too quick & smooth....well, not really. Lots of electrical challenges ahead.
First one is the USB3 front panel header.....
.....which plugs into this (this is the original motherboard):
I have never seen a USB3 connector like this.....so making it interface with a standard 19/20 pin will be a bit of a challenge.
Also, the RAID backplane power connectors were proprietary to that stupid power supply. I'm sure it's all simple 5v/12v, just have to figure out the pin config. Then there's all the front panel connectors for the buttons & LED's....all wired weird....so this one is nowhere near done.....but not a bad start for a decent workstation.
IO shield.
Booted to Hiren's.
Looks kinda cute!
