Wondering if anyone could offer any help with this motherboard I have acquired. The board apparently had a BIOS update and then wouldn't POST. I have tried several USB Bios Flashback attempts and also removed the BIOS chip and reprogramed it with a CH314a. Both haven't done changed anything. The board turns on the CPU light turns on then off. CPU gets hot like normal. If RAM or CPU removed then the corresponding light will light up. However the VGA and BOOT lights will never light up.
MSI B450 Gaming Pro Carbon AC wont post no debug lights
Re: MSI B450 Gaming Pro Carbon AC wont post no debug lights
The B450-era motherboards seem prone to failure. In my case, what looks like bad MOSFETs.Last edited by RJARRRPCGP; 05-19-2023, 07:35 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
16 GB AData XPG Spectrix D41
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
Originally posted by anikin73 View PostIt means the code did not run complete...msi mobo got 4 led, cpu, ram ,vga,and boot.
I guess your board stuck at cpu led....
Originally posted by OsamaObama View PostIt will get stuck at the CPU LED if there is no cpu installed. If a CPU is installed the board behaves as normal with the CPU light on then going off.
Originally posted by SMDFlea View PostWhat CPU does it have. Have you read the bios release notes for CPU compatibility
