Hello all ~
I am working on a PSU from a Philips 50# (50PF7220/37) plasma and needed to replace two bad caps at the bottom center of the board. I went at it too aggressively and ended up taking one pad off completely and another one nearly off. Hoping to get this back in order before proceeding any further.
BOTTOM OF BOARD:
If you take a look at the pic of the bottom of the board, you'll see (counting from the left) the first pad that is still there, but hanging to the run somewhat precariously.
The second one looks to be in tact still.
The third is the one I'm mostly concerned about, as this is the pad that came completely off (I still have the pad, and it's fully intact (i.e. circular)).
The fourth one seems to be in tact just like the second.
Looking for some expert advice on what I need to do to repair this before installing the two new caps (3300uf 10v 105 degree). Specifically, here are my questions:
1) Will I have to drill hole #3 and put in some kind of funnelet and then attempt to reattach to the trace run? Or, as is my hope, is there an easier way? As I mentioned, I still have the in-tact ring pad and that can simply be dropped back into the blackened hole. But, just soldering that back into place does not seem like it will make the proper connection to the run.
2) Given the type of board it is, do I need to be concerned about repairing both the bottom pads/traces, or the top, or both? I read a few forum posts that indicated I might be able to ignore one or the other, but could not make complete sense of that advice.
3) Can hole #1 simply be soldered after the new cap lead is dropped through? It is still attached to the run, but the ring itself looks like it might be compromised. Will the solder fill in any gaps and form a proper connection?
4) Do holes #2 and #4 look like they can be left alone?
TOP OF BOARD:
Also, I have included a photo of the top of the board too. Here, one of the small copper rings came off during the desoldering process and was lost. I am wondering how imperative it is to find or replace that before installing the new cap.
Thanks in advance for your replies / advice.
BOTTOM OF BOARD:
TOP OF BOARD:
