Toshiba password
    Re: Toshiba password
    Please Response Code For PROTEGE R830-1C2:
    PC SERIAL : ZB145918H
    Challenge Code : GY262-L80C5-FKBH4-G8P89-DQ6K6
      Your last 2 posts have been deleted.
      https://www.badcaps.net/forum/showpo...42&postcount=4 3. Password removal by laptop brand
      3.10. Toshiba
      3.10.2. Business
      Response generator is not available publicly, however, some generous people may be able to generate a response for you. Ask in this thread: https://www.badcaps.net/forum/showthread.php?t=79489
      Laptop must not be rebooted, the challenge will change.
        Challenge Code : V4X59-49QPV-DWVPG-D6H78-UL84H
          hi, help unlock this laptop
          SN: ZE019353H
          C.C: T6R9R-3M58N-G7VCF-J6TP7-6LY1L
          thanks
            Response Code = JT76M-N0D49-YXNQD-JEBCU-PHKJQ
              the pc has shutdown, the CC has changed, thank you anyway.
                Would it be possible to assist me on that matter please ?
                Tecra Z40-C
                Serial: 7J161169H
                Challenge: O5Wc804T49IHGlof8jlcfmKRIa1KzxyhnPDkVe0pqJnrFuLHkv vZ8DyG32Z0xi1tl9NovYNuqYDJcInM9dQq4HE9tQIaI53NAcSN fiXGTed3uJ6yxIN7ySRDiVbrHOfSwCX0FPJFqFPvcHGs0MRUlf mgPdmSbFBgKOGsri0zBoWaiReJWGTE3nwvZtgq3amdP4Sgd6Z0 E5A5B6aQtM7fRMrNNtrXajb642MgvpA9wdC6UrBKj1jZ12cJkz pHrfzbIbHiEPZ3n1eRtI9bsNnfRVaxKsU6f1QGoqpSgLPOOXY2 qYLlE8EkYg3dKheGBCJMpgAyzSEiKSeL9lMvhBItL4eCzomAzt sB61RrnAX6jEFwUCysKZp91
                Thank you !
                  Please:
                  Response Code For TOSHIBA PROTEGE R830
                  Challenge Code : D8YBP-QTXY4-HAT99-X9J4F-TNTNH
                  thanks
                    Originally posted by andicalman
                    Z30-C
                    {"Serial":"4J032773H","Challenge":"1iiMf6pfUeciQdwfPaYZ4tLxD7ZTjfyBVr5PaxYKYWcFdiW8sRJom7KswKbXR9oF5ulj7Y19wSS6am0AmXEBrRgWVtT6IEWf7jkXuOshUibQSmorsOb9BElUSk01pNreb9tmOj32JvqmsezrIyIKQz2a1j5IPrKfujJRnBP3BfRkkyu3Ew0eCemRON2VBFnIa4r46CSRQsZsAwMdMwHI4SwjcZPR4zoXR7NMU5qcnelAwoa0kIUIKpw6PFjNFDdyuJfmvdiDCA8wR814JBmgRP5Lz3oZnXw0Y9Pq3XvsFyATcifs5gbWwcze3WmBh5IRUe1QUrGWfS5wmGlUXzZXC3uWJZGGeZGPNqavvkCqJHAV3dScM"}
                    Thanks in advance
                    I flashed bios with older version and now got the following challenge please ignore the eurlier post and please could I get the response for the following.
                    Z30-C
                    Sn: 5G075318H
                    Challenge code RFQMU-V0706-DB1BV-CJ44P-4TA5D
                    Thank you
                      Z30-C
                      Sn: 5G075318H
                      Thank you
                      Response Code = DEK9K-V3GB9-NDENN-VT0QN-7UEGM
                        Thanks for the code, it unlocked, rebooted asked for password so I typed "pass" and it accepted it, it then said press f2 for bios to set date and time after reboot and then it's asking for password, I tried to type pass and it wouldn't accept. There no NVME drive on the laptop at the moment, could that be the reason?
                        SN: 5G075318H
                        Challenge code: TB26Q-TE9CE-1CMDL-5X1FM-B4NCX
                        any advice?
                          SN: 5G075318H
                          any advice?
                          Please ignore this as pc turned off 😭
                            Hi evserv, please could I get the response for the following.
                            SN 5G075318H
                            Challenge code: VXM7Q-LA98R-FLJXW-BLE0Q-P87XD
                            Going to give this laptop one last chance before I give up 😭
                            Thank you for all your help. Really appreciate it.
                              Please read this guide carefully first:
                              https://disk.yandex.ru/i/cENZg_8jLkwf8w
                              Response Code = 32E5Y-3B10A-GW2DX-PQKTW-7VE43
                                Hi evserv, thanks for the guide, it says to press the F2 button before the password screen and before getting the challenge/response. Unfortunately my eurlier post was just powering up the laptop without pressing F2 first so the computer did not enter BIOS
                                I entered your code and it said initialising Intel link storage, said to check cables and to enter BIOS with F2 when the Toshiba logo appears after reboot. I did a soft reset (CTRL ALT DEL) at the Toshiba logo I press F2 and it did not enter BIOS and just continue to the same Intel link storage page. Some Google search say to press F1 or F12 to enter BIOS but the computer itself is saying to press F2, it must be the right button, just I didn't know to press it before getting the challenge response code thing, I even tried a usb wireless keyboard and still didn't get to the BIOS. Any suggestions?
                                I've now powered it up pressing F2 and got the following challenge
                                SN 5G075318H
                                Challenge code: 9RVYL-0QMDK-G0FNP-T4GHC-VJNW3
                                I hope after entering this the response for the above challenge it will enter BIOS. If there was an os installed, I could have gone through windows 10 advance boot to UEFI bios.
                                  Response Code = CRXHY-JC6R5-6DWBG-QQWGQ-4M674
                                  This is your last chance...
                                    Please:
                                    thanks
                                      Thanks for the help, it wouldn't boot into the bios setup, so I got frustrated and repeated pressed F1, F2, F12 and delete, (after a Ctrl, alt and delete soft reset) and now its stuck on a blank screen.
                                      It is what it is, I'm probably going to just put it on eBay, going to avoid Toshiba's like the plague from now on.
                                      Thanks for all your help, I really appreciate it, it's people like you that makes the internet and world a better place, respects for all the work you do. Thank you
                                        Hello, can you send me response code please?
                                        Its Tecra A11 1D9
                                        pc serial: 6A028072H
                                        Challange: KY45B-880U1-R7R8C-Q2NTX-8JWYH
                                        It will active till 2023.03.12 ( on monday we have no electricity D )
                                        Thank you!
                                          Greeting
                                          I have a problem Toshiba Tecra Z50 C 14T
                                          PC SERIAL : ZG091050H
                                          Challenge Code : 6H0E2-6MRNC-KTQLW-143VW-YWXAD
                                          Thank you very much in advance
