Asus gl502vmk and gtx1060
    Asus gl502vmk, comes with a capacitor in short (caused by a short with a screwdriver or something like that), after the replacement the system worked fine, I played fallout 76 for two hours, temperatures ok no problem. I used the system for another two hours but next time I start with Steam and the same game:
    1 - BSOD irq not less or equal , nvlddmkm.sys
    2 - for a short time the gtx1060 is not detected
    Fix I have tried:
    1 - reinstalled windows 10
    2 - downloaded last nvidia drivers
    Results:
    1 - with passmark performance test the system returns an error 2003238900 only with directx 12
    2 - with 3dmark (directx 12) after loading the test, it stop and return an error same thing with direct x 11
    Other fix tried:
    1 - Removed the moisture and dust under the bga gpu with a ultrasonic wash at 60 c temp for 20 min
    2 - changed gpu firmware
    3 - with Dxdiag check no error related at directx 12
    This issue remain, usually it refer at gpu bga or vram ?
    Reprogrammin the bios can help ?
