Strange resistance readings on Radeon RX6800 VRM
    Hi guys
    I can't quite get my head around the resistance readings on this GPU
    On phase of Vcore VRM reads higher resistance than the others
    This 3 mins video shows exactly what I mean
    https://www.youtube.com/watch?v=NZR4otU77VE
    I can't think any way this could happen unelss one phase is not directly connected to the others, but is conetced via a low value resistance
    Can someone unconfuse me please
    Cheers
    Follow me on YouTube
    Learn Electronics Repair
    Re: Strange resistance readings on Radeon RX6800 VRM
    TBH, I'm not too familiar with these newer gen GPUs, so perhaps it is possible that this one phase is not connected to the others. Have you traced the MOSFETs for that phase to see if they are exactly connected like the MOSFETs on the other phases (and to the same controller)? I think that might be the first clue in telling if that's part of the GPU VRM or some secondary GPU VRM. I do agree that it's strange that only this one coil reads higher resistance, though. I'd expect to see at least another phase in parallel with it, if it was to be some secondary GPU VRM rail. On the other hand, if all of these phases were to be connected together, then the only way that higher resistance would be there is if the copper trace from the coil to the GPU chip has burned and gone high resistance... which I think would be highly unlikely.
      Hi Momaka
      Thanks. It shouldn't be too difficult to see if this phase goes to the same controller as the other phases, for example if there is an 8 phase VRM controller
      But I couldn't find a datasheet for the coil driver IC either so that does not exactly help
      Because this one phase still has a very low resistance to ground it also seems odd to me that it would be a singleton as you mentioned.
      I could just try powering the card up and measure the voltage on this and other inductors on the VRM - but I really would like to understand what I am looking at first.
        OK I pretty much got to the bottom of this - at least I have a plausible theory for the odd resistance readings on the VRM
        The fault on this card appears to be elsewhere
        It's easier to watch than for me to explain in detail what I worked out
        https://www.youtube.com/watch?v=ooefNfC8Lxg
        Rich
