Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 05-15-2019, 11:02 AM   #1
nwelec
City & State: bremerton,wa
My Country: usa
I'm a: Knowledge Seeker
Default panasonic TC-P65ST30 8 power led error code
TV has the 8 LED error code. This normally means the SS board is bad. If I follow the service manual and disconnect ss11 it still has the 8 error code but if I remove the cable to c23 from the ss board the tv has no error code and the tv stays on. Does this mean that the C2 board is bad or could it be the panel. I did check for continuity between pins 1 and 2 of ss61 and ss66 and they were fine.
nwelec is offline   Reply With Quote
Old 05-15-2019, 12:25 PM   #2
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: panasonic TC-P65ST30 8 power led error code
I suspect one of the cof is bad for the panel. Try disconnecting each of the connectors between the C2 and panel and see if it will stay on and give a picture (with black bar at disconnected plug)
R_J is offline   Reply With Quote
Old 05-15-2019, 01:05 PM   #3
nwelec
My Country: usa
I will try that, thanks.
Old 05-15-2019, 04:22 PM   #4
nwelec
My Country: usa
I tried what you suggested and still same issue. I guess maybe c2 board is bad.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
