Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 09-21-2017, 09:51 AM   #1
Doc38343
City & State: Humboldt, Tennessee
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Professional Tech
Default Samsung UN58H5202AF - killing mosfet.. no power
OK I read the other posts and found same burned board and Q9101 shorted as budm
So I replaced the Q9101 (ordered from mouser) anyway it worked great for 3 hours and blacked out so i pulled the board and same mosfet Q9101 is shorted again.. there are 3 very brown spots on this board over the two in the middle QM801cs and qm802cs also brown at the 4 diodes at very top of cold section DM841-844 C they seem to be getting hot also... i bought 5 mosfets but don't want to waste another without trying to isolate the cause.. a long shot could be a defective new part but i doubt that seeing the heat marks...
What would cause that mosfet to fail??
After checking all the diodes and other components on the board and they seem good.. so i put another new Mosfet on it Q9101.. this time i added some of the silicone heat sink to help cool the hot devices. I haven't run the set yet, but overnight two more things occurred to me..
1. could the capacitors cause this? they seem good but i did not pull them out of circuit.
2. Could the LED backlight brightness be too high causing this?
Perhaps experience could enlighten me.... Thanks
Doc38343 is offline   Reply With Quote
Old 09-22-2017, 09:06 AM   #2
Nick's Tvs
City & State: Tucson Arizona
My Country: USA
Line Voltage: 120vac 60hz
Default Re: Samsung UN58H5202AF - killing mosfet.. no power
We had the exact same set come into our shop, and the exact same transistor burnt out. We started off by doing exactly the same thing and replaced the transistor to have the exact same failure as you did but only within 10 minutes. From there, we decided to just purchase a power supply online to replace it. That power supply lasted about 4 days before yet again the exact same failure happened. After that we decided to purchase the entire kit from shopjimmy and proceeded to replace all of the boards. Once that was done, we yet again had another failure within two days. We gave up and refunded our customer at that point. The only parts not replaced were the LED strips, maybe somehow they failed and were causing the power supply to go out. All I can tell you is that our customer was pissed and that entire process was a pure nightmare.
Nick's Tvs is offline   Reply With Quote
Old 09-22-2017, 09:18 AM   #3
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
I'm a: Knowledge Seeker
What happen if you turn down the backlights level to 50% or less, also check the LED current by checking the Vdrops on the LED current sensing resistor.
That MOSFET is for the boost converter so may be the Boost converter inductor may be bad or the IC is not driving the MOSFET at the correct frequency. I would get the spec sheet of the LED driver IC and probe the circuit with scope.
__________________
budm is offline   Reply With Quote
Old 09-22-2017, 12:13 PM   #4
Doc38343
First thanks to both of you guys for helping.
What i did was pulled all the diodes and tested. tested caps.. they are ok also.
I put it all back and put the new mosfet on. Then went with the silicone solution to cool the 3 mosfet that are getting hot under the board. I also tested the backlights with the cheap little tester (did not pull the panels) the top pair pulled 98.6 from the tester.. the bottom pair pulled 68.7v.
I re-connected and powered on and the LED rail voltage (read from chassis to the top diode and the horizontal jumper near the jack) was 233.6v
The actual readings on the led connector were 101.4 at top pair and 86.9 at bottom pair.
I went into the menu and cut the LED level from 90% down to 50% it is still plenty bright, I think that was partially the problem. I could not find the service manual for this one and i am not paying $14.99 for it so I don't really have the optimum settings/voltages beyond the board markings. It has run 5 hours yesterday evening and about an hour so far today.. I will run it all day and test the temperatures with laser thermometer to see how it holds.
So far so good. Cooling may be the answer and undoubtedly the leds are getting older and drawing more current than when new. I think it was designed to fail in a calculable amount of time by Samsung design.
Old 08-06-2018, 05:03 PM   #5
funkmasterfrank
City & State: quebec
My Country: canada
Does anyone have another replacement part number other than the original Samsung part number? I would like to order from Digikey or mouser
funkmasterfrank is offline   Reply With Quote
Old 08-11-2018, 01:26 AM   #6
jjanssen7
City & State: Chilliwack, BC
My Country: Canada
This model is worst than most at burning out LEDS. On each TV of the 8 I've seem that mosfet is burned up and when I open up the TV many of the leds are burnt out. just sayin'
jjanssen7 is offline   Reply With Quote
Old 11-28-2018, 06:09 PM   #7
jetscreamer
City & State: o
My Country: Canada
Are you saying that bad led strips are causing q9101 to fail?
I've replaced the one I am working on twice now.... first time lasted a few hours. 2nd time I dimmed the leds to 50% and it has been on for 24hrs so far (thanks budm). My board is burnt in the same sport just like the original posters. Wish I had the testing voltages for the PSU board.
Used:
https://www.digikey.ca/products/en?k...EAUMA1CT-ND%20
jetscreamer is offline   Reply With Quote
Old 11-28-2018, 06:22 PM   #8
petehall347
City & State: worcester
My Country: United Kingdom
as far as see the led.s are turned up way too high in default settings ..i always turn them down whatever tv or monitor it is .
petehall347 is offline   Reply With Quote
Old 11-28-2018, 06:30 PM   #9
nomoresonys
City & State: midwest
My Country: U.S.
Looks like this model needs a re-design.
nomoresonys is offline   Reply With Quote
Old 11-28-2018, 08:06 PM   #10
budm
budm's Avatar
My Country: USA
Were some of the bad LED's shorted out?
Old 11-29-2018, 01:01 AM   #11
jjanssen7
My Country: Canada
I have repaired about 10-12 of this specific model. In EACH case I replaced some/most of the LEDS which were burnt out. Then, in EVERY case the power-supply needed to be replaced/repaired as well before backlights would turn on. I would make sure with testing and visual inspection that all LEDS are working before repairing the power supply. Doing things this way I've had a 0% return rate within a two year window.
Hard to say if the power supply is burning out that LEDS and then taking itself out or the other way around, but there seems to be a connection.
Old 12-17-2018, 03:14 PM   #12
shmasood
City & State: ontario
My Country: canada
Where did you get power supplies from. Also any instructions on accessing backlight lrds since I could not find service manual or youtube videos for this model.
shmasood is offline   Reply With Quote
Old 04-11-2019, 09:48 AM   #13
sputnikoff
City & State: happy valley newfoundland
My Country: canada
I have same issue with this set.There are 6 strips of leds inside at least 3-4 and some 5 leds gone on each row.
sputnikoff is offline   Reply With Quote
Old 04-11-2019, 08:44 PM   #14
sputnikoff
My Country: canada
power supply wouldn't fire up,even with cable to main board off.Q9101 was failed.Replaced and unit up and running.
Old 04-25-2020, 03:19 PM   #15
farog
City & State: Douala
My Country: Cameroun
Please i need help. I have the QM801CS and QM802CS transistors/mofset who is burn on this power supply (BN44-00787A) so i can't read what is write on it. Can you help me by giving me the references of these transistors?
farog is offline   Reply With Quote
Old 04-25-2020, 04:26 PM   #16
jaysonfp
City & State: orlando, fl
My Country: usa
Quote:
Sounds like the LED strips were bad.
jaysonfp is offline   Reply With Quote
Old 08-02-2020, 10:03 PM   #17
skiinggord
City & State: North Vancouver
My Country: Canada
14nm50n mosfets are QM801/802
skiinggord is offline   Reply With Quote
Old 08-16-2020, 12:18 PM   #18
Nick's Tvs
My Country: USA
Just an update, but as it has been mentioned by jjanssen7 replacing the LED strips is essential. We have always replaced all LED strips with a brand new remanufactured sets from shopjimmy in addition to replacing the faulty mosfet since our last post and have been succesful with ever repair after.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
