Hello friends, please i need help. some guys just messd up this tv by removing some igbt mosfet , so am having issue knowing the right component. can anyone who have very good insight about this tv tell me the real numbers and positions of the mosfets in the ysus board.
lg 42pt350r plasma
Re: lg 42pt350r plasma
30F124 and IRG71C28U are used, I have two of these tvs here because the "technician" that touched them destroyed the boards.
Information I found on the internet is:
Q708 Q709 - IRG71C28U
Q713 Q703 - 30F124
Q711 Q710 - FDP33N25
IC701 - ADUM1234
IC702 IC703 IC711 - FAN73711
The ADUM and FAN rarely fail.
The IRG are 600V high current IGBTs, I've read on forums about 30J127 and RJP63F3 could be used in their places, but there are slim chances of buying any of those that wouldn't be a fake.Last edited by Biruslapio; 09-16-2020, 02:54 PM.
Originally posted by hispeck View PostSo are you saying that 30j124 was not used in this ysus ? Tomorrow I will cross check with the list you just posted. Thanks a lot for your timeLast edited by Biruslapio; 09-18-2020, 01:45 PM.
none of them are working, and they won't for a long time until I can get a Y-SUS replacement because the dumbass that messed with them ripped all the traces out.
If the IGBTs or MOSFETs are defective, there will be a short between their pins, measuring at max 100 OHMs, pretty easy to spot the failure at these Y-SUS boards, the problem is getting original parts to replace with.
It has perfect image for a few minutes then blow up? probably counterfeit IGBTs, what are you replacing them with?
Chech the heatsinks for overheat, they probably can handle the peak voltage but not the current, this is why they fail.Last edited by Biruslapio; 09-19-2020, 04:51 PM.
