Sony Bravia no Picture
    Re: Sony Bravia no Picture
    "IE 3A": It may be is LF for Little Fuse. I use PICOII fuse 3A rating from DIGIKEY.
    Thanks for the reply! I'm a complete novice when it comes to fuses. I searched for PICOII and there are so many. Does it make a difference which one I choose (see link below on the search)? Those are the 3 amp fuses. Is one better than the other?
    Also does anybody have any comments on where to get the the 5A 24V micro fuse (breadcrumb) that is on the BU board. Would digikey have that under some other search parameters? Or can I just use another PICOII fuse?
    http://www.digikey.com/product-searc...=0&pageSize=25
    Thank you!!!!
      I get bulk, the yellow one is the slo-blo, the green on is fast-blo which is what I use.
        I have a problem with the F100 on tcon board, blown. My F1422 is ok as I have 12V to one side of the tcon fuse.
        Also had bent pin on tcon connector causing two pins to short together, probably due to not pulling the connector straight when removing.
        Anyone ever had fuse on tcon blow?
          I would love to find a tcon schematic, but doubt I will find one.
          Anyone know where I can get one? I have the manual with other boards.
            "Anyone ever had fuse on tcon blow?" yes.
              Hello, gents im having the same problem with my KDL-55EX713
              Screen started going bad with lines on the left hand side only.
              Then gradually went to the full screen. Then went washed out, and then completely black now.
              This was over about 2 hour period.
              Now if i turn it on, just a black screen.
              Could this be the t-con ? I visually looked at the power supply board and all the cap's look to be good. When i turn power on there is a click
              Any suggestions?
              Where can i find schematics for my model?
              Thanks guys!!
                Please do not post all over the place.
                heck for fuse on T-con board, near the connector coming from the mainboard.
                  Re: Sony Bravia KDL32XBR4 i get two click
                  Bravia KDL32XBR4 i get two click sound i nee help with this can i jump to see if inverter is bad or main board
                    do anyone have a schematic for a sony Bravia KDL32XBR4
                      @djpat1974, you should start a new thread since your TV is not the same model as in this thread.
                      And also:
                      https://www.badcaps.net/forum/showthread.php?t=39740
                        Originally posted by mbates14 View Post
                        I work on these stupid sonys all the time.
                        there is a VERY EXTREMELY SUPER MINI TINY fuse on the signal board that popped when the t-con went bad. I am thinking smaller than SMD0603
                        you must replace this fuse. This fuse supplies the 12V to the T-con board, and if popped, you will get no 12V to the panel.
                        These boards are riddled with tiny fuses. id say theres maybe 5 to 10 of them in various circuits. there is one popped, and i think its near the center of the board on the back side.
                        I have this tv with the same symptoms. When you say the signal board are you referring to main board with the inputs on it?
