Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Thread Tools Display Modes
Old 02-12-2021, 12:14 PM   #1
ramondo
Confused Member
ramondo's Avatar
City & State: youngstown,ohio
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Knowledge Seeker
Default USB inputs fail
I have an older Dell Optiplex 960 Windows 7 system that has been running fine for several years. Lately all Usb inputs have randomly stopped working (keyboard and mouse not recognized). I have run AV and SFC and MWB with nothing found. It does not matter which program is running (even in the middle of Solitaire) when problem occurs. Restarting PC does not fix the problem. Cannot enter BIOS SETUP MODE. However unplugging pc from wall power and replugging fixes problem for several days. Where should I look first to solve this problem,, or what actually gets depowered when unplugging a PC that is in the OFF state.
__________________
Thanks to all for being__WAR_KITTENS____!
ramondo is offline   Reply With Quote
Old 02-12-2021, 01:45 PM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: USB inputs fail
check the inside of the power supply for bulging or leaked capacitors.
i have seen this when the 5v standby voltage goes to shit.
dont ignore it - it can eventually damage the motherboard.
stj is offline   Reply With Quote
Old 02-13-2021, 12:13 AM   #3
Uranium-235
Muffins
Uranium-235's Avatar
City & State: tehas
My Country: US
also check your device manager for code 10's on the USB controller
__________________
Uranium-235 is offline   Reply With Quote
Old 02-16-2021, 02:56 AM   #4
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
I second this notion - I've seen bad caps on the 5VSB make USB and PS/2 devices drop out or act up. Given that it's a Dell, it probably has a Delta, HiPro, or LiteOn PSU. Many of those utilize CapXon, Teapo, and Ltec caps - none of which tend to last in the long run (especially the Ltecs)... which is a shame, because those PSUs are otherwise well-made. I usually recap them, though. After that, they are pretty much bullet-proof (save for a few specific models that do have known problems - but even these tend to be reliable overall.)
Old 02-25-2021, 08:57 AM   #5
jackyjoy123
City & State: indi
My Country: indi
Quote:
thanks my issue has been fixed.
jackyjoy123 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
