Just curious, does anyone see any problem caps on my aging amp that I should keep an eye on, are any of these tantalum? Or ones that could potentially go due to age?
See any caps here that I should be concerned about on an aging amp?
Re: See any caps here that I should be concerned about on an aging amp?
The electrolytics all look like "off brand" Taiwanese/Chinese stuff (and 85C rated) that could definitely be suspect. Though audio gear generally isn't too "hard" on caps compared to something like an SMPS so I've seen even "sub par" caps last a long time in audio gear.
Doesn't really look that old. Looks fine to me
what about the main power board? That is the one you really need to be concerned about. These look like the speaker ampsCap Datasheet Depot: http://www.paullinebarger.net/DS/
This is an Aragon 2005 THX 5 channel amp from 2003ish era
Originally posted by Uranium-235 View PostDoesn't really look that old. Looks fine to me
Better view of the caps, black ones are Hitano and the blue ones say what seems to be AE
Wow. Looks so clean. Is that a linear PSU? Ohh it has a pre-amp and those are the full speaker output amps
yeah that looks fine. High quality shit thereCap Datasheet Depot: http://www.paullinebarger.net/DS/
Originally posted by Uranium-235 View PostWow. Looks so clean. Is that a linear PSU? Ohh it has a pre-amp and those are the full speaker output amps
But even with these caps, if I power off the amp music will keep.playing for 14 seconds before the caps start to fully drain.Last edited by demoncamber; 01-06-2021, 12:30 PM.
I read you can use a bleeder resistor, but have more or less no clue how to implement it on this type of amp. Another solution is to turn off the pre-amp before you turn off the main ampCap Datasheet Depot: http://www.paullinebarger.net/DS/
Originally posted by Uranium-235 View PostI read you can use a bleeder resistor, but have more or less no clue how to implement it on this type of amp. Another solution is to turn off the pre-amp before you turn off the main amp
