Hi, guys. This TV stopped to accept commands and it does not matter if i am using my remote control or the buttons on the TV. It is accepting it sometimes but only once or something and then it is stopping again. Only the volume command is working even i cannot see the graphic scale every time. But the volume is working - i can adjust the volume without problems. I reset the TV few times but it is the same. Now it stuck on the Welcome Screen and i cannot move forrward. Do you think that the Main Board could be a problem?
SONY KDL 43w805c does not accept commands
Re: SONY KDL 43w805c does not accept commands
Originally posted by dick_barton View PostIf you disconnect the wifi connector does that help. I think it's connected to the IR sensor module.?
IR SENSOR WIFI MODULE SIDE CONTROL BUTTONS FOR 43" SONY BRAVIA KDL-43W805C TV
its much firmware issue, as its android 5. there are update for years 2019 to this set- you need to try
1- hard reset from power & volume - then plug it in wall socket..
2- to by pass the first installation and to to apply update use air mouse with the tv. or any USB 2 mouse.Last edited by Diah; 01-14-2021, 08:52 AM.
Originally posted by zen View PostOnly one company i know in the UK that can repair main board .
I believe they advertise service on E BAY .
Company name is Micro tech .
Originally posted by Diah View Postits much firmware issue, as its android 5. there are update for years 2019 to this set- you need to try
Originally posted by Dobsuk View PostSo, did hard reset few times but did not try with the mouse. Will try it now. The TV is with the last firmware downloaded from sony website.
take the batteries out from your RC in case the RC keep sending IR signal.. then use the side control panel .. you can try android APK too if you have android mobile with IR sender such galaxy S5. i think sony they have apk too to control the set via net work too.
Originally posted by Diah View Postwith mouse you can setting the tv as u like... the Notification graphic scale should work again after the hard reset... because its can turned off via setting.
Just tried with the mouse now and nothing - i can see the mouse coursor and move it for 2-3 sec and then it is freezing for few sec and so on.... Is there how to reflash the TV with USB stick even it is with the latest firmware already?Last edited by Dobsuk; 01-15-2021, 08:56 AM.
Originally posted by Dobsuk View PostYeah, but the point is it stuck on the welcome screen. So, i cannot use any APK to control it via the network until the tv is not connected to the network. And my problem is not that this volume graphic is missing... The problem is that it does not accept command neither from the remote control nor from the side control panel.
put the last update firmware on USB stick not larger than 4GB formatted FAT 32... inset it in USB Port Ver 2. and do the procedure as you doing hard reset. you need to release the power & Volume - only when you see the usb led indicator start blinking. do it many time until you succeed. if this not help need to open the cover and show me the main boards to see which version its.Last edited by Diah; 01-15-2021, 09:44 AM.
Originally posted by Diah View Postf you did hard reset as press power and Volume - then plug set in AC and it show for you erase on screen .. then Air mouse will work.
Thank you, Diah!Last edited by Dobsuk; 01-15-2021, 10:42 AM.
Originally posted by Dobsuk View PostYEah it is working but for few seconds only... then it is freezing for few secs and so on.
Originally posted by Dobsuk View PostFound some procedure for downgrade on Internet but cannot find older firmware for my TV.
Thank you, Diah!
and this eua sony_tvupdate_2015_2637_eua_auth.zipLast edited by Diah; 01-15-2021, 11:30 AM.
just to be sure you did hard reset correct..
1-while the set on plug it out from wall socket
2- plug out any cable / antena etc from the set ( keep it solo )
3- press on the tv side panel volume - & power and keep press then plug it in wall ac again.. the front LED will change to green... after it change to green release the keys you pressed before.
4- leave the set it will reset and it will show you first install but it will reset again and reboot..--- this mean after the set rebooted 2 time and the first install remain on screen the set finished reset.
you must use air mouse. because its plug & play with androidLast edited by Diah; 01-15-2021, 11:42 AM.
Originally posted by Diah View Postthere are 2 kind of regions android 5 for Sony 2015 as yours w805c so i listed for you very early version for eua ...
Originally posted by Dobsuk View PostThank you! I am going to try some of them now....
I tried and using your advice, Diah
