need bios dump dell latitude 5420 (cpu 11th)
    Re: need bios dump dell latitude 5420 (cpu 11th)
    Originally posted by hoaca388 View Post
    Try this file , if it not work re-flash your original file (the one with the password) and see if it works.
    if it works with the original I just tried it
      thanks with that it works
        please help me unlock
          The file you posted is corrupted.
          Become a Badcaps supporter
          Thanks to all supporters.
            hi i need bios dump dell latitude 5420 clean
              Post your original corrupt bios file here.
                hi its
                  hi its
                  Missing, there is also the second bios chip.
                    ic 2
                      Which programmer are you using? The both backup files are not good, the error may be your programmer. Each chip should make 3 backups to test.
                        ezp2023+
                          hi is there any way around it to remove pass
                            2 options. Contact dell with proof of ownership if its still under warranty, or buy a different programmer
                              Hello. Please help unlock Bios admin password for my file.
                              Dell Latitude 5420. Service tag is on file name.
                                This machine is very new.
                                  need bios unlock for dell 5420. brand new to this stuff but when i hooked it up to programmer to get dump it found four of them not sure which to upload here so hes all of them. :? if someone could help would really appreciate it.
                                    Wrong chip.
                                      NEVER MIND. I UNLOCKED IT BY MYSELF
                                        Yes it is.
                                          Originally posted by aldopc View Post
                                          I don't understand do you need to unlock?
                                          Hi, I tried to unlock it but it won't start.This is the original file.
